Fermion: MEMS Multi-Gas Detector - CO/CH4/Ethanol Sensor (1-1000ppm, Breakout)
$9.90
SKU: SEN0440
  • $9.70 3+ items
  • $9.50 5+ items
  • $9.20 10+ items
The sensor detects gases like CO, CH4, H2, and NH3 using MEMS technology, offers low power consumption, analog output, and supports I2C digital output.
This industrial MEMS sensor detects 8+ hazardous gases including CO (1-1000ppm), CH4 (>1000ppm), and ethanol (10-500ppm) - essential for chemical plants, refineries, and air quality stations.
8-Gas Detection Capacity
Simultaneously monitors carbon monoxide, methane, ethanol, propane, butane, hydrogen, hydrogen sulfide, and ammonia - critical for complex industrial environments.
Ultra-Low Power Operation
0.45W consumption with enable/disable pin reduces energy use by 40% in continuous monitoring systems (5V DC compatible with PLCs and microcontrollers).
Smart Analog Output
Generates linear 0-5V signals proportional to gas concentrations, with pre-loaded conversion formulas for instant Arduino/Raspberry Pi integration.
Extreme Environment Ready
Withstands -30°C to 85°C temperatures and 95% humidity - 3x more durable than standard sensors in oil/gas applications.
  • Supports detection of 8 common gases
  • Compact 16mm² footprint fits control panels
  • Compatible with Fermion MEMS series (NO2, VOC, H2S)
  • Sample code for IoT gateway integration
  • Oil refinery gas leak detection
  • Brewery/distillery ethanol monitoring
  • Agricultural NH3 safety systems
  • Parking garage CO/CH4 detection
  • Industrial HVAC air quality control
  • Detection Ranges:
             CO: 1-1000ppm | CH4: >1000ppm
             Ethanol: 10-500ppm | H₂: 1-1000ppm
             NH3: 1-500ppm | H2S: 1-1000ppm
  • Output: Analog voltage (0-5V DC)
  • Response Time: <20 seconds
  • Power: 5V ±0.1V, 0.45W
  • Operating Temp: -30°C to 85°C
  • Lifespan: 2+ years continuous use
  • Dimensions: 12×16mm (Breakout)
  • Interface: 3-pin Gravity connector
  • Fermion: MEMS Gas Sensor - MiCS-5524 x1
  • Black pin header-3Pin x1
    Jun 26, 2022
