Fermion: MEMS H2 & NOx Gas Detector - MiCS-2714 Sensor (1-1000ppm, Breakout)
$9.90
SKU: SEN0441
  • $9.70 3+ items
  • $9.50 5+ items
  • $9.20 10+ items
MEMS sensor detects NO, NO2, and H2 gas concentrations with low power use, analog output, and supports 5V power. Ideal for gas leak and air environment detection.
This industrial-grade MEMS sensor detects dangerous H2 (1-1000ppm) and NOx (0.05-10ppm) concentrations with 85°C temperature tolerance - critical for chemical plants and manufacturing safety.
Multi-Gas Detection Capability
Simultaneously monitors hydrogen (H2), nitric oxide (NO), and nitrogen dioxide (NO₂) - three of the most dangerous industrial gases with explosive/toxicity risks.
Low-Power Operation
0.45W consumption with enable/disable pin control extends battery life in continuous monitoring systems (5V DC compatible with Arduino/Raspberry Pi).
Precision Analog Output
Generates linear voltage signals (0-5V) proportional to gas concentrations, ready for integration with PLCs and microcontrollers via included conversion formulas.
Industrial Durability
Withstands extreme -30°C to 85°C environments and 95% humidity (non-condensing) - outperforms standard environmental sensors in harsh conditions.
Fermion: MEMS Gas Sensor - MiCS-2714
Board Overview
  • Pre-loaded concentration algorithms
  • Compact 16mm² footprint for embedded systems
  • Compatible with Fermion MEMS series (CO, NH₃, H₂S)
  • Sample code for Arduino/PLC integration
  • Hydrogen fuel cell leak detection
  • Industrial plant safety systems
  • Automotive emissions testing
  • Environmental monitoring stations
  • Laboratory gas analysis setups
  • Detection Range: H₂: 1-1000ppm | NO₂: 0.05-10ppm
  • Output: Analog voltage (0-5V DC)
  • Response Time: <30 seconds
  • Power: 5V ±0.1V, 0.45W
  • Operating Temp: -30°C to 85°C
  • Lifespan: >2 years (normal use)
  • Dimensions: 12×16mm (Breakout board)
  • Interface: 3-pin Gravity connector
  • Fermion: MEMS Gas Sensor - MiCS-2714 x1
  • Black pin header-3Pin x1
    Jun 26, 2022
    Jul 27, 2023
