This Gravity: ENS160 Air Quality Sensor, based on ScioSense's new ENS160 sensor chip, is specifically designed for indoor air quality monitoring and offers detection of multiple IAQ data (TVOC, eCO2, AQI).
The innovative TrueVOC™ technology combines the metal oxide (MOX) technology that brings this sensor superior accuracy, fast response, anti-interference, etc. With intelligent on-chip algorithms, the ENS160 can directly output rich and easy-to-understand environmental data. Preheat the sensor 3 minutes before use then you can obtain accurate data more quickly. What's more, the built-in automatic baseline correction algorithm ensures the long-term stability of the sensor.
Board Overview
Connection Diagram
Apr 12, 2024
Mega cool sensor to accurately measure air quality. With Python PinPong library, coding is super easy and quick. I think the same result should be possible with Adurino (did not test yet). Highly recommended!
Jun 04, 2023
Excellent sensor for VOC measurement; simple and easy to implement.
May 18, 2023
This is a great sensor for detecting VOCs and for indoor Air Quality monitoring. Using this sensor you can create a Air Quality index monitor along with thresholds to alert you when there is an increase in air pollutants. The sensor responds quickly to changes in the air quality and through I2c gives the raw data values as well as an air index value.
