DFRobot Gravity: MAX30102 heart rate and blood oxygen sensor module integrates the Maxim MAX30102 chip and an MCU with heart rate and blood oxygen algorithm.
The MAX30102 uses PPG(PhotoPlethysmoGraphy) to measure data, which will be converted into heart rate and oximetry values when processed by the MCU, then output through I2C or UART, making the sensor easy to use and greatly reducing resource occupation of the main controller. Meanwhile, the corresponding upper computer is provided to allow you to conveniently read data by a PC.
Note:
Wear Instructions
Connect with DFRduino UNO R3
Connect with Raspberry Pi
Dec 31, 2024
As many Gravity sensors from DFRobot - easy to connect and very easy to develop applications with it. Few lines of Python code and results were working.
