Gravity: Geiger Counter Module Ionizing Radiation Detector
$60.00
SKU: SEN0463
  • $58.00 3+ items
  • $57.00 5+ items
  • $55.00 10+ items
The Geiger counter detects ionizing radiation but not electromagnetic radiation. It's suitable for research and teaching, not professional safety measurements.
Purchase this product and earn 600 reward points, which are tied to VIP membership program. Learn More >
Ionizing radiation, an invisible and intangible enemy, exists not only in nuclear power plant reactors. In fact, we are bombarded by radiation from the surrounding environment and outer space all the time, and fortunately, our body is strong enough to resist the natural background radiation.
No active contact does not mean that high-energy ionizing radiation will not be encountered. Natural marble building materials, ore gems with different colors, and "negative ion powder" of unknown composition may contain different amounts of radioactive elements. With a Geiger counter, these radioactive sources have nowhere to hide.
The Geiger counter can only detect ionizing radiation, such as nuclear radiation, X-rays, cosmic rays, etc. Electromagnetic radiation such as microwave oven radiation, mobile phone radiation, WiFi radiation, induction cooker radiation can not be detected.
In addition, the Geiger counter is a good random number generator, and undetermined high-energy particle ionization events can provide enough random entropy to get you a truly random number, rather than a fixed random sequence based on a random algorithm.
Note
This product is not a professional measuring instrument and is only suitable for principle research and teaching demonstration. Not for use in radiation dose measurement that directly affects personal safety.
  • Large-scale and highly sensitive Geiger tube
  • Easy to install layout
  • Ionizing Radiation Detect
    Geiger Counter
  • Power Supply: 3.3V ~ 5V
  • Signal Output: digital output, pull down when pulse detected
  • Driving Voltage: ≈400V
  • Maximum Range: 1200 μSv/h(theoretically)
  • Outline Size: 107 x 42mm/4.21 x 1.65”
  • M4011 Geiger Tube
  • Operating Voltage: 380V ~ 450V
  • Background Counts: ≈25CPM
  • CPM Ratio: 153.8 CPM/(μSv/h)
  • Outline Size: Φ10mm x 88mm
  • Gravity: Geiger Counter Module (Geiger Tube Included) x1
  • Gravity 3 - Pin Sensor Connector x1
    2022 Top 10 New Products
    Blog 2022 Top 10 New Products
    Jan 10, 2023
    Projects Ionizing Radiation Detector
    KGray
    Jun 25, 2024
    Making a Desktop Geiger Counter with Unihiker --- Real-Time Nuclear Radiation Monitoring
    Projects Making a Desktop Geiger Counter with Unihiker --- Real-Time Nuclear Radiation Monitoring
    Afra
    Dec 01, 2023
    IoT AI-driven Food Irradiation Dose Detector w/ Edge Impulse
    Projects IoT AI-driven Food Irradiation Dose Detector w/ Edge Impulse
    Kutluhan Aktar
    Jun 28, 2022
    Geoff.Wheeler May 23, 2025
    Exellent device, digital output makes installation and programing easy and provides desired output data.
    Ronald.Luijten Feb 01, 2024
    This is a very good looking part at a reasonable price. I can recommend
    Damjan. Oct 28, 2022
    Works as intended. Although it would be nice if PCB had a USB connector for power. Detects radiation quite happily.
