Gravity: 2-Channel I2C DAC Module (0-10V)
$9.90
SKU: DFR0971
  • $9.70 3+ items
  • $9.50 5+ items
  • $9.20 10+ items
The 2-channel I2C DAC module outputs 0-10V for industrial devices and supports 8 I2C addresses, allowing control of 16 devices via Arduino programming.
This 2-Channel I2C DAC module can output a voltage of 0-10V, which is a standard driver in industrial applications. It can be widely used with most 0-10V devices on markets such as light controllers, inverters, valves, pumps, etc, by Arduino programming.
Besides, this module supports 8 different I2C addresses, which can be changed using the on-board DIP switch, allowing a cascade of 16 devices.
2-Channel 0-10V I2C DAC Module
Click here to get Selection Guide of DAC Modules
  • Support 3.3V-5V power supply
  • Output voltage error is less than 0.5%
  • Output short-circuit protection
  • Two-channel 0-5V/0-10V output for connecting to and controlling standard analog voltage devices
  • Gravity interface, I2C communication, Arduino control, suitable for program automation control
  • Adjustable 8-way I2C addresses, able to control 16 devices at the same time
  • Intelligent function signal generator
  • Automatic controlling of lighting or fountain
  • Automatic and quick transformation of small equipment
  • Automatic debugger for electromechanical equipment
  • Transformation of small test equipment
  • Operating Voltage: 3.3V~5V
  • I2C Interface: PH2.0-4P (Gravity Line Sequence)
  • Chip Type: GP8403
  • Input Signal: 12Bit (0x000 - 0xFFF)
  • Input I2C Signal High Level: 2.7V - 5V
  • VOUT0 Output Voltage: 0 - 10V
  • VOUT1 Output Voltage: 0 - 10V
  • Output Voltage Error: < 0.5%
  • Linearity Error of Output Voltage: 0.1%
  • Power Consumption: < 4mA
  • Output Short-circuit Protection
  • Gravity: 2-Channel 0-10V I2C DAC Module × 1
  • Gravity I2C/UART Sensor Cable × 1
    Blog Selection Guide of DAC Modules
    Oct 25, 2023
    2022 Top 10 New Products
    Blog 2022 Top 10 New Products
    Jan 10, 2023
    Kaj Ronny.Nilsen Dec 08, 2025
    Great I2C DAC module, very easy to setup and use, as well as having an unbeatable price.
