Gravity: 2-Channel I2C DAC Module (0-10V)
$9.90
SKU: DFR0971
  • $9.70 3+ items
  • $9.50 5+ items
  • $9.20 10+ items
The 2-channel I2C DAC module outputs 0-10V for industrial devices and supports 8 I2C addresses, allowing control of 16 devices via Arduino programming.
This 2-Channel I2C DAC module can output a voltage of 0-10V, which is a standard driver in industrial applications. It can be widely used with most 0-10V devices on markets such as light controllers, inverters, valves, pumps, etc, by Arduino programming.
Besides, this module supports 8 different I2C addresses, which can be changed using the on-board DIP switch, allowing a cascade of 16 devices.
2-Channel 0-10V I2C DAC Module
Click here to get Selection Guide of DAC Modules
  • Support 3.3V-5V power supply
  • Output voltage error is less than 0.5%
  • Output short-circuit protection
  • Two-channel 0-5V/0-10V output for connecting to and controlling standard analog voltage devices
  • Gravity interface, I2C communication, Arduino control, suitable for program automation control
  • Adjustable 8-way I2C addresses, able to control 16 devices at the same time
  • Intelligent function signal generator
  • Automatic controlling of lighting or fountain
  • Automatic and quick transformation of small equipment
  • Automatic debugger for electromechanical equipment
  • Transformation of small test equipment
  • Operating Voltage: 3.3V~5V
  • I2C Interface: PH2.0-4P (Gravity Line Sequence)
  • Chip Type: GP8403
  • Input Signal: 12Bit (0x000 - 0xFFF)
  • Input I2C Signal High Level: 2.7V - 5V
  • VOUT0 Output Voltage: 0 - 10V
  • VOUT1 Output Voltage: 0 - 10V
  • Output Voltage Error: < 0.5%
  • Linearity Error of Output Voltage: 0.1%
  • Power Consumption: < 4mA
  • Output Short-circuit Protection
  • Gravity: 2-Channel 0-10V I2C DAC Module × 1
  • Gravity I2C/UART Sensor Cable × 1
    Blog Selection Guide of DAC Modules
    Oct 25, 2023
    2022 Top 10 New Products
    Blog 2022 Top 10 New Products
    Jan 10, 2023
