Gravity: I2C SCD41 Infrared Carbon Dioxide / CO2 Sensor (400 - 5000 ppm)
$44.90
SKU: SEN0536
The sensor measures CO2, temperature, and humidity with high accuracy, small size, and low power consumption. Ideal for indoor air quality monitoring.
Purchase this product and earn 449 reward points, which are tied to VIP membership program. Learn More >
CO2 is a key factor for indoor air quality as high levels compromise human cognitive performance and well-being.
This Gravity: SCD41 CO2 sensor is based on the SCD41 miniature CO2 sensor from Sensirion. SCD41 builds on the photoacoustic NDIR sensing principle and Sensirion’s patented PAsens® and CMOSens® technology to offer high accuracy at an unmatched price and the smallest form factor. On-chip signal compensation is realized with the built-in temperature and humidity sensor, while temperature and humidity data outputs are also available.
SCD41 sensor detects the amount of energy that is absorbed by CO2 molecules. When pulsing the infrared emitter, CO2 molecules absorb infrared light periodically. This causes additional molecular vibration resulting in a pressure wave inside the measurement chamber. The higher the CO2 concentration, the more light is absorbed, and thus the greater the amplitude of this acoustic wave becomes. A microphone inside the gas chamber measures this, from which the CO2 concentration can then be calculated.
Click to learn more about PAsens® technology.
Click to learn more about NDIR sensors.
Gravity: SCD41 Infrared CO2 Sensor - I2C
Selection Guide
CO2 Sensor Selection Guide
Figure
SKU
SEN0678
SEN0159
SEN0220
SEN0219
SEN0536
Operation Voltage
3.3 ~ 5V
3.7~5V
4.5~5.5V
4.5~5.5V
3.3V-5V
Output
Gravity: I2C
Gravity: Analog (Analog2.7~4.1V) + 3P Header Digital Output(Alarm):0~VCC Level
Gravity: Analog (Analog Output 0.4~2V)
Gravity: UART (0~3.3V Level)
Gravity: I2C
Measurement Principle
Thermal Conductivity (TC)
Electrochemistry (Solid electrolyte battery principle)
NDIR (non-dispersive infrared)
photoacoustic NDIR
Measurement Range
400 ~ 5000 ppm
0~10000 ppm
0~50000 ppm
400~5000 ppm
400~5000 ppm
Accuracy
±(100 ppm + 10% of reading)
±100ppm@400ppm
±(100ppm + 6% readings)
±(40 ppm + 5% MV)
Response Time
<20s
<20s
<90s
<30s
60s
Average Power
<4.8mW@5V (950μA continuous)
<1W
<430mW@5V
<430mW@5V
<30mW@5V
Operation Temperature
10℃ ~ 40℃
-20℃~50℃
0℃~50℃
0℃~50℃
-10℃~60℃
Operation Humidity
20 ~ 80% RH (non-condensing)
0~95% RH (No condensation)
Dimension (PCB)
32*22 mm
32*42 mm
37*69 mm
21*27.1 mm
32*27*8mm
1. 3-in-1 (CO2, Temp, Humidity) 2. High cost-effectiveness 3. Low power (1μA sleep) 4. Auto compensation 5. I2C Plug and play
1. Large Range 2. Adjustable Alarm Threshold 3. Fast Response 4. Analog Output
1. High Accuracy 2. Long Lifespan 3. Auto Temperature Compensation 4. Water Vapor Interference Resistance 5. Ananglog Output
1. High Accuracy 2. Large Range 3. Long Lifespan 4. Auto Temperature Compensation 5. Water Vapor Interference Resistance 6.3.3V UART Output
1.CO2, temperature, and humidity, three in one 2. Small size of 32*27*8mm 3. Low power, average current<4mA
Add to Cart
  • CO2, temperature, and humidity, three in one
  • Small size of 32*27*8mm
  • Low power, average current<4mA
  • Indoor CO2 concentration monitoring
  • Ambient monitoring in greenhouse
  • Smart ventilation systems
  • Power Supply: 3.3V to 5V
  • Average Operating Current: <4mA
  • I2C Address: 0x62
  • Product Size: 32*27*8mm/1.26×1.06×0.31"
  • CO2
  • Accuracy: ±(40 ppm + 5% MV)
  • Measuring Range: 400 - 5000 ppm
  • Response Time: 60s
  • Humidity
  • Typical Relative Humidity Accuracy: 6%RH
  • Relative Humidity Measuring Range: 0 to 95%RH
  • Response Time: 120s
  • Temperature
  • Typical Temperature Accuracy: 0.8℃
  • Temperature Measuring Range: -10 to 60℃
  • Gravity: SCD41 Infrared CO2 Sensor x1
  • Gravity-4P I2C/UART Sensor Cable x1
    Certifications
    How a Photoacoustic CO2 Sensor Works
    Blog How a Photoacoustic CO2 Sensor Works
    Dec 06, 2023
    How to Choose the Best CO2 Sensor for Arduino / ESP32 Project (2026 Selection Guide)
    Blog How to Choose the Best CO2 Sensor for Arduino / ESP32 Project (2026 Selection Guide)
    Mar 26, 2026
    How to Design and Construct Indoor Air Quality Monitoring System
    Blog How to Design and Construct Indoor Air Quality Monitoring System
    Jun 01, 2023
    Exploring the Components of Gases Human Breath In and Out With SCI and Air Sensors
    Projects Exploring the Components of Gases Human Breath In and Out With SCI and Air Sensors
    Qinchan.Wang
    Oct 16, 2023
    Explore how plants photosynthesize
    Projects Explore how plants photosynthesize
    Qinchan.Wang
    Oct 16, 2023
    Making a CO2 Concentration Alert Keychain with Infrared SCD41 Photoacoustic Sensor
    Projects Making a CO2 Concentration Alert Keychain with Infrared SCD41 Photoacoustic Sensor
    Frances
    Apr 06, 2023
    JORGE.VALERIO ARAOZ May 31, 2025
    Excellent sensor, easy to connect thanks to its I2C protocol, and easy to configure. The examples included in the library are beneficial. I wish it were more affordable. Otherwise, highly recommended.
    Jens.Gilbers Feb 27, 2026
    I use this sensor in my grow setup in the tent and all measurements of temperature, humidity and CO2 are accurate and very reliable :)
