mmWave - C4001 24GHz Human Presence Detection Sensor for Arduino & ESPHome (25 Meters, UART)
$13.90
SKU: SEN0609
  • $13.60 3+ items
  • $13.30 5+ items
  • $12.90 10+ items
The sensor detects human presence and motion up to 25m using 24GHz millimeter-wave technology. It features strong anti-interference, FMCW modulation, and versatile installation.
Upgrade smart automation with the C4001 24GHz mmWave Sensor. Unlike traditional PIR sensors that only detect large movements and fail when occupants remain still, this sensor utilizes advanced FMCW (Frequency-Modulated Continuous Wave) technology to detect micro-motions such as human breathing.
Engineered for long-range and high-precision applications, it accurately detects human presence up to 16 meters and motion up to 25 meters, making it ideal for large living spaces, long corridors, and comprehensive security monitoring.
Why Choose the C4001?
  • True Presence Detection: Accurately senses people who are sitting, lying down, or even sleeping.
  • High Environmental Immunity: Unaffected by temperature, humidity, dust, light, or noise.
  • Long-Range Sensing: Covers areas up to 25m, significantly outperforming standard 9m or 5m radars.
  • Effortless Integration: Designed for compatibility with Arduino, ESPHome, Home Assistant, and other popular DIY platforms.
  • Detection Range of millimeter-wave human body sensor
    mmWave vs. PIR: A Decisive Technological Upgrade
    This comparison highlights why mmWave radar is the superior technology for modern smart automation.
    Simplified & Straightforward Integration
    The C4001 24GHz mmWave sensor is designed for easy implementation. With a simple wiring setup, the C4001 can be operational within a project in a short amount of time.
    Wiring diagram of the C4001 millimeter-wave human body sensor and Arduino Uno
    How It Works: The FMCW Advantage
    The C4001's precision is derived from its Frequency-Modulated Continuous Wave (FMCW) radar technology. It continuously emits a signal and analyzes frequency shifts in the return wave. This method allows it to determine an object's distance and, through the Doppler effect, detect microscopic movements—such as breathing—which is the key to its unparalleled static presence detection capability.
    Flexible Installation Options
    For optimal performance, the installation method should be chosen to suit the intended application. Top-down installation is ideal for room-wide coverage, while tilted or horizontal installation is better for directional sensing in specific zones.
    Top Installation Diagram of c4001 millimeter-wave human body sensor
    Top Installation Diagram of millimeter-wave human body sensor
    Bottom Installation of millimeter-wave human body sensor
    Horizontal Installation of millimeter-wave human body sensor
  • Human detection: Detection range up to 16 meters and motion detection range up to 25 meters.
  • Distance detection: Range from 1.2 meters to 25 meters.
  • Velocity detection: Range from 0.1 meters per second to 10 meters per second.
  • Strong anti-interference capability, unaffected by snow, haze, temperature, humidity, dust, light, noise, etc.
  • High and low-level output control through I/O ports.
  • Input and output control via serial port.
  • Small size, easy to integrate.
  • Smart Bathroom: Ensures lights and exhaust fans remain active as long as the space is occupied, then shut off automatically when vacant. This provides a hands-free, convenient, and energy-efficient solution.
  • Advanced Security Monitoring: Unlike motion detectors prone to false alarms from environmental factors, the C4001 detects actual human presence. This allows for security systems that provide more meaningful alerts when individuals linger in a protected area.
  • Intelligent Energy Management: In offices or living spaces, the C4001 24GHz mmWave sensor enables precise occupancy-based control of HVAC, air purifiers, and lighting systems. Equipment runs only when rooms are occupied, maximizing energy savings.
  • Applications of mmWave - C4001 24GHz Human Presence Detection Sensor for Arduino & ESPHome
  • Operating Voltage: 3.3V / 5V
  • Operating Frequency: 24GHz
  • Modulation Mode: FMCW
  • Maximum Motion Detection Range: 25m
  • Human Presence Detection Range: 16m
  • Distance Measurement Range: 1.2m to 25m
  • Velocity Measurement Range: 0.1 m/s to 10 m/s
  • Beam Angle: 100° x 40°
  • Communication: I/O, UART
  • Default Baud Rate: 9600
  • Operating Temperature: -40℃ to 85℃
  • Dimensions: 26mm x 30mm
  • C4001 mmWave Presence Sensor 25m × 1
  • 5-pin header × 1
    Old MacDonald had a FARM, and became a safer driver
    Projects Old MacDonald had a FARM, and became a safer driver
    Hackster.io
    Jan 06, 2023
    Human Presence Detection with mmWave C4001
    Media Human Presence Detection with mmWave C4001
    Makerguides
    Apr 06, 2026
    How Accurate are mmWave Sensors?
    Blog How Accurate are mmWave Sensors?
    May 04, 2023
    Millimeter Wave vs Microwave
    Blog Millimeter Wave vs Microwave
    Apr 27, 2023
    Exploring the Diversity of Human Presence Detection Technology Solutions
    Blog Exploring the Diversity of Human Presence Detection Technology Solutions
    May 29, 2024
    DIY Smart Bathroom Light: with ESPHome & Home Assistant!
    Tutorial DIY Smart Bathroom Light: with ESPHome & Home Assistant!
    Mellow_Labs
    Aug 19, 2024
    KOUBELAN RICHARD.AKPAGNI Nov 08, 2025
    Impressive 24 GHz mmWave sensor with outstanding range and accuracy! The C4001 detects human presence up to 25 meters, even through light materials like curtains or thin walls. I used it with ESP32 and ESPHome — integration via UART was straightforward, and the readings are extremely stable with no false triggers. It’s perfect for smart lighting, security, or occupancy monitoring systems where PIR sensors fail. The detection sensitivity and delay time can be fine-tuned easily. A reliable, professional-grade sensor for anyone building advanced IoT or home automation projects. Excellent performance and documentation from DFRobot!
    Ayaz.Ahmed May 03, 2026
    I have developed a human absence alert system and working fine.
    Chad.Downey Mar 31, 2026
    Received in good condition, and works as it should!
