Lite Carrier Board for LattePanda Mu Compute Module (USB 3.0, Ethernet, PCIe 3.0, M.2 M key, HDMI)
$39.00
SKU: DFR1142
  • $38.00 3+ items
  • $37.00 5+ items
  • $36.00 10+ items
Lite carrier board for computer modules with USB, Ethernet, PCIe, M.2 slots, HDMI, wide voltage input, and open-source design for embedded system projects.
Purchase this product and earn 390 reward points, which are tied to VIP membership program. Learn More >
This lite carrier board(Base Board) is specifically designed for the LattePanda Mu computer-on-modules. Together with the LattePanda Mu, this carrier board forms a comprehensive development platform, akin to a Single Board Computer (SBC). It incorporates the most frequently used interfaces such as USB 3.0, Ethernet, PCIe 3.0, M.2 M key, M.2 E key, HDMI, and more. This allows for the connection of a variety of external devices and modules, enabling swift verification and testing of diverse design solutions, thus reducing the product development cycle. It is ideally suited for application in embedded system design.
Integrated Common Interfaces
This lite carrier board includes USB 3.0, Ethernet, PCIe 3.0, M.2 M key, M.2 E key, HDMI, etc. Its comprehensive integration design and compact size make it more convenient to use and cost-effective.
Wide Voltage Input
This lite carrier board supports a wide voltage input of 12~20V, allowing direct connection to a 4S lithium battery without the need for an additional voltage regulator module. This wide voltage input design greatly enhances the product's adaptability and portability.
PCIe 3.0 x4 Expansion Slot
This lite carrier board is equipped with a standard PCIe 3.0 x4 slot, allowing you to easily expand various peripherals, such as graphics cards, sound cards, network cards, etc., providing more powerful performance for your project (this interface is only available when paired with a 12V power supply).
M.2 Expansion Slot
In addition to the PCIe slot, this carrier board also comes with M.2 M key 2230 and M.2 E key 2230 slots, which can easily expand SSD hard drives and WLAN wireless network cards, bringing more possibilities to your project.
3.5-inch Standard Size
This lite carrier board uses the standard size of 3.5-inch embedded motherboards, which is extremely convenient for installation and pairing with other devices. This standardized design allows it to seamlessly integrate into your various projects and systems.
Open-source Design
The schematic and PCB design files of this carrier board are provided. Utilize these as reference materials to fine-tune according to your specific needs, significantly reducing development time and cost.
Note:
1. It needs to be paired with the LattePanda Mu compute module to use.
2. Before plugging or unplugging LattePanda Mu, any cables, or internal interfaces, it is necessary to disconnect the power supply.
3. The PCIe slot of the lite carrier is available only when using a 12V power supply.
4. It requires a spring-loaded DC 2.0 male plug for power supply.
Versatile Carrier Boards
DFRobot offers a lite carrier board for the LattePanda Mu, providing a comprehensive development platform with various interfaces for swift design verification.
Additionally, a full-function evaluation carrier board is available, exposing all pins of the LattePanda Mu for extensive hardware and software testing.
Carrier boards of LattePanda Mu
  • Wide voltage input
  • Gigabit Ethernet
  • 2 x USB3.2 10Gbps, 2x USB 2.0
  • HDMI 2.0, supports 4K video output
  • PCIe 3.0 x4 expansion slot
  • Dual M.2 expansion slots
  • 3.5-inch embedded motherboard standard size
  • Open-source Design
  • Auto power-on
      Power Input
  • USB Type-C: 15V (Max 3A)
  • DC 5.5x2.5mm: 12~20V (Max 10A)
  •   Internal Interfaces
  • PCIe 3.0 x4 slot (only available when using 12V power supply)
  • M.2 M Key 2230 (PCIe 3.0 x1)
  • M.2 E Key 2230 (PCIe 3.0 x1, USB2.0)
  • RTC battery socket (CR1220 3V)
  • CPU fan socket
  • Gravity-4P UART
  • Gravity-4P I2C
  • MX1.25-10P Connector (for LattePanda UPS Expansion board)
  •   External Interfaces
  • USB 3.2 10Gbps x2
  • Gigabit Ethernet
  • USB 2.0 x2
  • HDMI 2.0
  • USB Type-C (for power supply only)
  • DC 5.5x2.5mm
  • Size: 3.5 inches, 146mm×102mm
  • Lite Carrier board x1
  • Acrylic Base Plate x1
  • Screw Pack for Lite Carrier board x1
  • CR1220 Button Battery x1
    AI-driven Sound and Thermal Image-based HVAC Fault Diagnosis
    Projects AI-driven Sound and Thermal Image-based HVAC Fault Diagnosis
    Kutluhan Aktar
    Aug 09, 2024
    The PVM-PANDA
    Projects The PVM-PANDA
    ArnovSharma1
    Jul 11, 2024
    PixelPanda: a 3D Printed RGB Matrix PC Build
    Projects PixelPanda: a 3D Printed RGB Matrix PC Build
    Mukesh Sankhla
    Jun 18, 2024
    Duane.Cree Mar 17, 2026
    I love how compact and organized the board is for only being roughly 5 1/2 inches
    David. Feb 09, 2026
    Excellent value product
    Andrew.Wickens Jan 24, 2026
    Clean layout and very practical carrier board. This Lite carrier board is easy to work with and exposes the most useful interfaces of the LattePanda Mu without unnecessary bulk. PCIe and M.2 support work reliably, networking is stable, and it’s a great base for custom enclosures and compact systems.
