Aluminum Passive Thin Heatsink for LattePanda Mu Compute Module
$4.90
SKU: FIT0982
  • $4.80 3+ items
  • $4.70 5+ items
  • $4.60 10+ items
The LattePanda Mu Thin Heatsink is an aluminum alloy cooler for the LattePanda Mu Compute Module, offering efficient heat dissipation. It requires additional fan use.
The LattePanda Mu Thin Heatsink is a high-quality cooler designed specifically for the LattePanda Mu Compute Module. It allows for perfect integration between LattePanda Mu and the carrier board, enabling you to freely build various DIY projects. This heatsink ensures stable temperature for your LattePanda Mu, and the heat dissipation fins quickly absorb the heat generated by the CPU. This simple yet effective method keeps your LattePanda Mu in its best condition at all times! The aluminum alloy housing has excellent thermal conductivity and comes with high-quality phase change materials for even better heat dissipation performance.
Installation steps:
1. Remove the three spring screws of the heatsink and peel off the phase change material protective film.
2. Align the CPU of the LattePanda Mu with the phase change material of the heatsink and align the screw holes.
3. Tighten the three spring screws in a circular motion until the installation is complete.
Be careful not to fully tighten one screw before loosening another, as it may cause damage to the CPU chip due to uneven force.
Note: Compatible solely with the LattePanda Mu model.
1. This model is a passive heatsink, which requires users to separately match it with a fan or design it for use inside a casing with airflow. It cannot be used as a standalone completely fanless heatsink.
2. When installing or removing the heatsink, the LattePanda Mu must be powered off
3. During use, please avoid direct contact between your skin and the case to prevent burns
LattePanda Mu Computer Module and Thin Heatsink
  • All-metal material
  • Wall-mounted
  • Passive cooling aluminum alloy heatsink
  • Aluminum alloy material, corrosion-resistant and durable
  • Compatible: LattePanda Mu
  • Dimensions: 70 * 45 * 11mm
  • Material: Aluminum alloy
  • Weight: 50g
  • Attention: This model is a passive heatsink, which requires users to separately match it with a fan or design it for use inside a casing with airflow. It cannot be used as a standalone completely fanless heatsink.
  • LattePanda Mu Thin Heatsink x1
  • Review
    David. Feb 09, 2026
    Excellent value product
    Andrew.Wickens Jan 24, 2026
    Great low-profile heatsink for compact builds. Fits the LattePanda Mu perfectly and provides effective passive cooling in tight spaces. Build quality is solid, installation is simple, and it’s ideal for silent or low-power setups where an active fan isn’t needed.
