Small-Angle Ultrasonic Ranging Sensor for Water Level Detection (25-800cm, IP67, 15°FOV)
$149.00
SKU: SEN0627
  • $146.00 3+ items
  • $143.00 5+ items
  • $138.00 10+ items
Ultrasonic sensor measures distances from 25 to 800 cm with high precision, fast response, and low power. Ideal for water level detection in challenging environments.
Purchase this product and earn 1490 reward points, which are tied to VIP membership program. Learn More >
Small Angle Ultrasonic Ranging Sensor‑8m is a compact ultrasonic distance measurement module designed for accurate long‑range detection in environmental monitoring and industrial installations. Using intelligent signal processing circuitry combined with high‑precision ranging algorithms, this ultrasonic distance sensor measures targets from 25 cm to 800 cm with ±2 cm accuracy and 1 cm resolution. A narrow 15° detection field, extremely low quiescent current, and rugged IP67 waterproof protection make this narrow‑beam ultrasonic module suitable for outdoor sensing tasks. Compatible with an Arduino development board, the distance sensing unit enables reliable monitoring of obstacles, liquids, and water levels in smart infrastructure and environmental IoT deployments.
Small Blind Area for Close‑Range Detection
This ultrasonic measurement module features a minimum detection distance of only 25 cm, significantly reducing the blind zone common in traditional ranging sensors. Such short‑range capability allows reliable monitoring in confined environments where the sensor must be installed close to the measured surface. Applications including liquid level monitoring, container distance sensing, and compact enclosure measurements benefit from improved accuracy even when measurement space is limited.
small-angle ultrasonic ranging sensor small blind area
Figure: Small blind area ultrasonic detection
Narrow Beam Angle (15° FOV) for Precise Targeting
A 15° field of view creates a focused acoustic beam that minimizes interference from surrounding structures. Such narrow‑angle ultrasonic detection improves measurement stability in shafts, tanks, pipelines, and other confined environments. Compared with wide‑angle distance sensors, this focused ultrasonic ranging device reduces false echoes from nearby surfaces and ensures reliable detection of the intended obstacle or liquid surface.
ultrasonic ranging sensor features Narrow Beam Angle
Figure: Narrow beam ultrasonic detection pattern
High Precision Measurement with Fast Response
Advanced ranging algorithms and intelligent signal processing circuitry deliver stable measurements with 1 cm resolution and ±2 cm accuracy. Response times between 0.9 s and 2.5 s enable continuous monitoring of dynamic environments such as water level changes or moving obstacles. Low power consumption, including a quiescent current below 10 µA and operating current under 15 mA, allows efficient integration into battery‑powered monitoring systems and remote IoT sensing nodes.
IP67 Rugged Protection with Temperature Compensation
Industrial‑grade sealing provides IP67 dustproof and waterproof protection, allowing reliable outdoor operation in harsh weather and wet environments. Integrated temperature compensation automatically corrects environmental temperature deviations, maintaining measurement stability across a wide operating range from -15 °C to 60 °C. Such durability makes this environmental distance sensing module well suited for infrastructure monitoring and long‑term deployment in exposed installations.
ultrasonic ranging sensor IP67 protection level
Figure: IP67 waterproof ultrasonic sensor structure
This long‑range ultrasonic measurement solution is widely used in smart infrastructure and environmental monitoring systems. Typical deployments include smart manhole water level monitoring, reservoir and storage tank liquid level detection, and river level observation systems where accurate distance sensing and strong environmental protection are essential.
  • 25 cm small blind area for close‑range detection
  • 15° narrow field of view for precise measurement
  • High precision with low power consumption and fast response
  • IP67 waterproof protection with onboard temperature compensation
  • Strong anti‑interference performance for outdoor monitoring
  • Smart manhole cover water level detection
  • Reservoir water tank liquid level detection
  • River water level detection
  • Working voltage: DC3.3~5V
  • Quiescent current: <10uA
  • Working current: <15mA
  • Measurement distance: 25~800cm
  • Measurement accuracy: ±2cm
  • Measurement resolution: 1cm
  • Probe frequency: 40khz
  • Output mode: UART controlled output
  • Angle: 15°
  • Response time: 0.9~2.5S
  • Working temperature: -15~60°C (with temperature compensation)
  • Storage temperature: -25~70°C
  • Protection level: IP67
  • Small Angle Ultrasonic Ranging Sensor‑8m ×1
  • 4Pin sensor cable ×1
    Only 15 Left
