ZL9NSQ 3D Wireless IMU Sensor (0.05° Static Accuracy, 250Hz Output, Bluetooth)
$69.00
SKU: DFR1179
  • $68.00 3+ items
  • $67.00 5+ items
  • $65.00 10+ items
The ZL9NSQ is a 3D sensor module with accelerometer, gyroscope, and magnetometer, offering precise attitude data via RF, UART, and SPI for various applications.
Struggling with motion drift in VR prototypes or robot stabilization? The ZL9NSQ 9-axis IMU sensor eliminates calibration headaches with 0.05° static accuracy and <1°/hr heading drift – outperforming typical MEMS sensors by 3x. Compatible with Arduino, Raspberry Pi, and ROS systems, this Cortex-M4F powered module streams 250Hz raw data while resisting magnetic interference.
ZL9NSQ Wireless Centrale Inertielle IMU Sensor Module for posture monitoring
Military-Grade Motion Capture
9-axis fusion (accelerometer/gyro/magnetometer) detects subtle movements down to 0.01° resolution – critical for surgical robotics and drone stabilization. ±16g accelerometer range captures high-G impacts without saturation.
Wireless Freedom with Zero Latency
Bluetooth 5.0 + UART/SPI enables cable-free integration in VR headsets or wearable tech. The pre-loaded IMU Motion Engine processes data onboard, reducing host CPU load by 60% compared to raw sensor kits.
Developer-Ready Platform
Open-source SDKs support Python, C++, and ROS2. Chain multiple IMUs via SPI for full-body motion tracking systems. Includes auto-calibration algorithms that compensate for temperature shifts (-30°C to 70°C).
Power-Optimized Design
Operates at 180μA standby current with dual power inputs (3.3V/5V). The 10,000-hour MTBF ensures reliability in 24/7 industrial applications like CNC machine monitoring.
  • High-performance, high-precision IMU
  • Integrated three-axis accelerometer, three-axis gyroscope, three-axis magnetometer
  • 3 communication methods: RF, UART, SPI
  • Can provide quaternion, Euler angle, acceleration, angular velocity and other three-dimensional attitude information
  • Posture monitoring
  • Gaming and entertainment equipment
  • Personal health and fitness
  • Inertial navigation
  • Applications of ZL9NSQ Wireless Centrale Inertielle IMU Sensor Module
  • Working voltage: J1-USB Type-C (5V), P2-PH2.0 (3.3V), P4-VCC (5V)
  • Communication method: RF (Bluetooth), UART, SPI
  • Pitch/cross accuracy (static): 0.05°
  • Pitch/cross accuracy (dynamic): 0.1°
  • Heading accuracy error (magnetometer assisted): 0.5°
  • Relative heading error (static): <1°/hr
  • Relative heading error (dynamic): 5°/hr
  • Angle resolution: <0.01°
  • Angle repeatability: <0.1°
  • Sensor raw data output rate: Max 250Hz
  • Navigation data output rate: Max 250Hz
  • Accelerometer Parameters
  • Range: ±16g
  • Zero bias stability: 2mg
  • Initial zero value: 40mg
  • Scale factor error: ±0.06%
  • Nonlinearity: ±0.1%
  • Axis alignment error: ±0.05°
  • Noise density: 75ug/√Hz
  • Bandwidth: 260Hz
  • Gyroscope Parameters
  • Range: ±2000°/s
  • Bias stability: 5°/hr
  • Initial zero value: 0.2°/s
  • Scale factor error: ±0.05%
  • Noise density: 0.0028°/s/√Hz
  • Bandwidth: 256Hz
  • Magnetometer Parameters
  • Range: ±4900uT
  • Bias stability: 20nT
  • Scale factor error: ±0.09%
  • Nonlinearity: ±0.3%
  • Noise density: 0.14nT/√Hz
  • Bandwidth: 200Hz
  • ZL9NSQ Wireless Centrale Inertielle IMU Sensor Module x1
  • 2.54-10Pin pin header x2
  • Only 3 Left
