ZL9NSQ 3D Wireless IMU Sensor (0.05° Static Accuracy, 250Hz Output, Bluetooth)
$69.00
SKU: DFR1179
  • $68.00 3+ items
  • $67.00 5+ items
  • $65.00 10+ items
The ZL9NSQ is a 3D sensor module with accelerometer, gyroscope, and magnetometer, offering precise attitude data via RF, UART, and SPI for various applications.
ZL9NSQ Wireless Centrale Inertielle IMU Sensor Module delivers high‑precision motion sensing for robotics, wearable electronics, VR tracking, and industrial monitoring. Built around a 9‑axis inertial measurement architecture combining accelerometer, gyroscope, and magnetometer data, this motion tracking module provides accurate attitude calculation with 0.05° static accuracy and heading drift below 1°/hr. A built‑in Cortex‑M4F processor performs onboard sensor fusion while streaming data up to 250Hz. Broad compatibility with Arduino and Raspberry Pi platforms allows seamless integration into robotics controllers, embedded navigation systems, and advanced motion‑capture applications.
ZL9NSQ Wireless Centrale Inertielle IMU Sensor Module for posture monitoring
Figure: ZL9NSQ wireless 9-axis IMU module
Figure: Motion tracking demonstration
High‑Precision 9‑Axis Motion Tracking
This inertial sensing module integrates a three‑axis accelerometer, gyroscope, and magnetometer to provide full 9‑axis motion fusion. Advanced algorithms calculate quaternion, Euler angle, acceleration, and angular velocity data with resolution better than 0.01°. Static pitch and roll accuracy reach 0.05°, enabling reliable orientation detection in precision robotics and stabilization systems. A ±16g acceleration range ensures accurate motion capture even during high‑impact events, making the sensor platform suitable for drones, mobile robots, and biomechanical movement analysis.
Wireless and Multi‑Interface Connectivity
Integrated Bluetooth RF communication enables cable‑free data transmission for wearable electronics, VR peripherals, and distributed sensing networks. Alongside wireless capability, UART and SPI interfaces provide flexible integration with embedded controllers and single‑board computers. This multi‑interface IMU platform supports both wired and wireless system architectures, allowing rapid prototyping and deployment across robotics research, smart equipment, and IoT motion‑sensing projects where reliable orientation feedback is required.
Onboard Motion Engine with High Data Throughput
An embedded processing core performs real‑time sensor fusion and navigation computation, delivering stable attitude information without heavy host‑side processing. Raw sensor data and calculated navigation output both support rates up to 250Hz, enabling responsive control loops for balancing robots, drone stabilization, and motion capture rigs. Built‑in algorithms compensate for sensor drift and magnetic disturbances, allowing consistent orientation tracking across dynamic environments and long‑duration operation.
Robust Platform for Industrial and Research Systems
This inertial navigation module is engineered for long‑term reliability in continuous monitoring applications. Stable bias characteristics, low noise density, and high repeatability ensure consistent measurement results across temperature changes and demanding environments. Support for chaining multiple sensors through SPI allows scalable motion‑tracking setups such as full‑body capture systems or distributed robotics sensing networks. Such capabilities make the module well suited for industrial equipment monitoring, research laboratories, and advanced motion‑analysis systems.
Typical deployments include posture monitoring systems, VR gaming peripherals, wearable fitness tracking devices, and inertial navigation solutions. The compact 9‑axis attitude sensing platform also supports robotics control, motion‑capture experiments, and smart equipment diagnostics where accurate real‑time orientation data improves system stability and responsiveness.
  • High-performance, high-precision IMU
  • Integrated three-axis accelerometer, three-axis gyroscope, three-axis magnetometer
  • Supports three communication methods: RF (Bluetooth), UART, SPI
  • Outputs quaternion, Euler angle, acceleration, angular velocity and other three-dimensional attitude information
  • Posture monitoring
  • Gaming and entertainment equipment
  • Personal health and fitness
  • Inertial navigation
  • Applications of ZL9NSQ Wireless Centrale Inertielle IMU Sensor Module
    Figure: Typical application scenarios of the 9-axis IMU module
  • Working voltage: J1-USB Type-C (5V), P2-PH2.0 (3.3V), P4-VCC (5V)
  • Communication method: RF (Bluetooth), UART, SPI
  • Pitch/cross accuracy (static): 0.05°
  • Pitch/cross accuracy (dynamic): 0.1°
  • Heading accuracy error (magnetometer assisted): 0.5°
  • Relative heading error (static): <1°/hr
  • Relative heading error (dynamic): 5°/hr
  • Angle resolution: <0.01°
  • Angle repeatability: <0.1°
  • Sensor raw data output rate: Max 250Hz
  • Navigation data output rate: Max 250Hz
  • Accelerometer Parameters
  • Range: ±16g
  • Zero bias stability: 2mg
  • Initial zero value: 40mg
  • Scale factor error: ±0.06%
  • Nonlinearity: ±0.1%
  • Axis alignment error: ±0.05°
  • Noise density: 75ug/√Hz
  • Bandwidth: 260Hz
  • Gyroscope Parameters
  • Range: ±2000°/s
  • Bias stability: 5°/hr
  • Initial zero value: 0.2°/s
  • Scale factor error: ±0.05%
  • Noise density: 0.0028°/s/√Hz
  • Bandwidth: 256Hz
  • Magnetometer Parameters
  • Range: ±4900uT
  • Bias stability: 20nT
  • Scale factor error: ±0.09%
  • Nonlinearity: ±0.3%
  • Noise density: 0.14nT/√Hz
  • Bandwidth: 200Hz
  • ZL9NSQ Wireless Centrale Inertielle IMU Sensor Module x1
  • 2.54-10Pin pin header x2
  • Only 19 Left
