M.2 (B+M Key) to 2.5G Ethernet Network Card for LattePanda (Supports Windows 10 / 11, Linux)
$25.90
SKU: FIT1005
  • $25.00 3+ items
  • $24.50 5+ items
  • $24.00 10+ items
High-speed M.2 2.5G network card with Intel chipset, supports up to 2500Mbps. Compatible with Windows/Linux systems and various board computers for stable connectivity.
The M.2 2.5G Network Card is a high-speed networking solution designed to enhance the Ethernet performance of compatible devices via an M.2 B+M Key slot. Powered by the Intel I225-V chipset, it enables adaptive data rates up to 2500Mbps, offering a reliable and efficient upgrade for systems like LattePanda Alpha, LattePanda 3 Delta, LattePanda Sigma single board computers, and other devices running Windows 10/11 or Linux. Ideal for applications requiring stable, high-speed network connections, this network card is a perfect choice for smart computing and advanced network configurations.
High-Speed 2.5G Performance with Intel I225-V
Equipped with the Intel I225-V chipset, this M.2 2.5G network card supports data rates up to 2500Mbps, providing fast, stable, and energy-efficient connectivity. Perfect for high-demand applications, the chipset ensures reliable and consistent network performance for smooth data transmission.
Broad Compatibility and Plug-and-Play Convenience
This network card supports a wide range of systems, including Windows 10/11 and Linux, and is compatible with LattePanda Alpha, Sigma, and 3 Delta motherboards. Its plug-and-play design enables quick installation, making it easy to expand networking capabilities without additional setup.
Wiring Diagram of LattePanda Alpha and M.2 2.5G Network Card
Wiring Diagram of LattePanda 3 Delta and M.2 2.5G Network Card
Flexible Network Connectivity Across Multiple Topologies
Supporting 2500BASE-T, 1000BASE-T, 100BASE-TX, and 10BASE-TE topologies, the network card adapts to different network environments and automatically adjusts data rates as needed. This flexibility allows for seamless integration in various configurations, ensuring a strong, stable connection across all network types.
LattePanda Ethernet Network Card Selection Guide
  • Smart computing
  • Chip: Intel I225-V
  • Interface: M.2 B+M Key
  • Transmission rate: 10/100/1000/2500Mbps adaptive
  • Network topology: 2500BASE-T, 1000BASE-T, 100BASE-TX, 10BASE-TE
                                        lEEE 802.3bz, IEEE 802.3, IEEE 802.3x, IEEE 1588, IEEE 802.3az
  • Network interface type: RJ45
  • Operating system: Windows10/11, Linux
  • Operating temperature: 0~55°C
  • Storage temperature: -40~70°C
  • Cable length: 210mm
  • M.2 board size: 22*80mm
  • RJ45 board size: 33*30mm
  • M.2 (B+M Key) Network Card x1
  • 2.5G Ethernet Port x1
  • Data Cable x1
    Only 5 Left
