LattePanda IOTA Palm-sized x86 Single Board Computer (Intel N150, 8GB RAM / 64GB eMMC)
$129.00
SKU: DFR1226
Notice: Limited to 1 pieces per customer.
Palm-sized x86 single-board computer featuring an Intel N150 quad-core processor, 8GB of LPDDR5 RAM, and 64GB of eMMC storage. It integrates an RP2040 co-processor for real-time I/O tasks.
Purchase this product and earn 645 reward points, which are tied to VIP membership program. Learn More >
LattePanda IOTA is a palm-sized, high-performance x86 single-board computer (SBC), engineered as a bridge between rapid prototyping and commercial deployment. As the next generation of the classic LattePanda V1, It integrates a powerful Intel Processor N150 with a versatile RP2040 co-processor, delivering a significant leap in computing power within a compact footprint. Key differentiators include its high speed LPDDR5 memory with IBECC for enhanced reliability, broad compatibility with desktop operating systems like Windows and Ubuntu, and a range of hardware configurations to meet diverse performance and budget needs. Designed for seamless system upgrades and future-proof applications, the LattePanda IOTA is the definitive choice for industrial automation, intelligent gateways, advanced robotics, and interactive digital installations.
Seamless Upgrade: Retains the classic LattePanda V1 form factor for easy project migration
Maintaining the compact design (88mm x 70mm) and interface layout of the LattePanda V1, LattePanda IOTA enables effortless upgrades nearly without mechanical redesign or enclosure modifications, significantly reducing development time and preserving project continuity.
LattePanda IOTA - Seamless Upgrade: Retains the classic LattePanda V1 form factor for easy project migration
8x Faster Performance
With the Intel Twin Lake N150 quad-core processor (up to 3.6GHz) and LPDDR5 high-speed memory, LattePanda IOTA offers 8x the CPU performance of LattePanda V1, ensuring ample performance and multitasking capability for most applications.
LattePanda IOTA Benchmark
LattePanda IOTA Faster Performance
Palm-Sized Design
Measuring only 88mm x 70mm, this compact LattePanda IOTA can be easily embedded into space-constrained applications like robots, smart terminals, and portable inspection devices—greatly expanding deployment possibilities for embedded systems at the edge.
LattePanda IOTA Palm-Size
Flexibility in Performance and Energy
LattePanda IOTA supports a configurable TDP (thermal design power) ranging from 6W to 15W, allowing you to balance power consumption and performance according to the application scenario.
  • 6W mode: Enables fanless, silent operation, suitable for noise-sensitive embedded systems or quiet environments.
  • 15W mode: Utilized with an active cooler to full performance, easily handling high-load computing tasks.
  • LattePanda IOTA Flexibility in Performance and Energy
    Rich I/O Connectivity
    LattePanda IOTA provides a practical and comprehensive set of interfaces, including 3x USB 3.2 Gen2 (10 Gbps) ports, a Gigabit Ethernet port, HDMI 2.1 and eDP dual video outputs, plus M.2 E-Key and PCIe FPC expansion interfaces, which easily meets various peripheral connections through a single board.
    LattePanda IOTA Rich I/O Connectivity
    Intel N150 + RP2040, Dual-Processor Collaboration
    Alongside the Intel N150 processor, LattePanda IOTA also integrates an RP2040 co-processor, which features a dual-core Arm Cortex-M0+, offers abundant GPIOs, and can be dedicated to real-time I/O control, sensor data acquisition, motor drive tasks, or even emulate a custom HID device. This design effectively reduces the load on the main processor and enhances system responsiveness and functional versatility.
    LattePanda IOTA Intel N150 + RP2040, Dual-Processor Collaboration
    Various Expansion Boards
    With dedicated expansion boards, the LattePanda IOTA can easily enhances its key capabilities:
  • UPS Expansion Board: A plug-and-play uninterruptible power supply. It provides up to 8 hours of runtime, auto power-on, and safe shutdown to protect the project from power loss. (Note: 18650 Batteries not included).
  • 51W PoE Expansion Board: Power the IOTA and get Gigabit data through a single Ethernet cable. Compliant with the IEEE 802.3bt standard, it's perfect for remote installations.
  • M.2 M-Key Expansion Board: Add a standard M.2 M-Key slot to the IOTA. Use it to connect a high-speed NVMe SSD for massive storage expansion or an AI accelerator card for edge computing tasks.
  • M.2 4G LTE Expansion Board: Grant the IOTA cellular network connectivity. Perfect for remote monitoring, mobile robots, and field-deployed devices. (Note: 4G LTE module and SIM card are not included).
  • LattePanda IOTA Intel N150 + RP2040, Dual-Processor Collaboration
    Recommended Accessories
    For a complete out-of-the-box experience, we highly recommend the LattePanda IOTA Accessories Kit, which includes the required heatsink, wifi modules, and other essential components.
    Important Notice
  • Heatsink Required: To ensure stable performance and prevent damage from overheating, a heatsink must be installed on the board before its first use.
  • No Operating System Included: This model does not come with a pre-installed OS. You will need to provide and install your own licensed operating system (e.g., Windows, Ubuntu).
  • Features
  • Retains the compact form factor and interface layout of the LattePanda V1
  • Intel N150 processor (up to 3.6 GHz, 4 cores / 4 threads)
  • Onboard 8GB LPDDR5 memory, supports IBECC
  • Onboard 64GB eMMC storage
  • Configurable TDP: 6 W to 15 W
  • Multi-OS support: Windows 10, Windows 11, Ubuntu
  • Rich expansion interfaces, including: 3× USB 3.2 Gen 2 (10 Gbps) ports, Gigabit Ethernet, HDMI 2.1 and eDP dual video outputs, M.2 E-Key and PCIe FPC expansion interfaces
  • Flexible expansion board options, supporting M.2 M-Key (NVMe storage expansion or AI acceleration), PoE, UPS, 4G LTE and other modules
  • Processor: Intel® Processor N150, 4C / 4T, up to 3.60 GHz
  • Memory: 8GB LPDDR5 4800MT/s with IBECC supported
  • Storage: 64GB eMMC 5.1
  • Display:
            HDMI 2.1, up to 4096 x 2160@60Hz
            eDP 1.4b, 2 Lanes, up to 1920 x 1080@60Hz
  • USB Ports:
            3x USB 3.2 Gen 2 Type A(10Gbps)
            1x USB 2.0 Pin Header
            1x USB Type-C PD 15V(Power supply only)
  • Network: 1x 1GbE RJ45 Port (Support WOL)
  • Expansion Slots:
            1x M.2 E Key 2230 Slot
            1x TF Card Slot
            1x PCIe FPC Connector
  • Co-processor: RP2040 MCU
  • GPIO & Other Features
            Up to 3x Analog Inputs
            Up to 16x Digital Input/Output
            1x UART
            1x USB 2.0
            1x PH2.0 4-Pin Connector(for power input)
            1x RTC Battery Connector
            1x DIP Switch
            1x Power Management Connector
            1x Fan Port
  • Audio: 3.5mm Microphone Headphone Combo Connector
  • Operating System: Windows 10 & 11, Ubuntu 22.04 & 24.04
  • Environment: 0~60°C; 0~80% relative humidity
  • Power Supply:
            USB Type-C: PD 15V
            PH2.0 4-Pin Connector: 10-15V DC
  • Size: 88mm x 70mm x 19mm
  • LattePanda IOTA (N150 8GB/64GB) x1
  • CR2032 3V RTC Battery x1
  • Product Manual x1
    令和に蘇るワープロ専用機?Intel N150で作るキーボード+液晶一体型PC
    Media 令和に蘇るワープロ専用機?Intel N150で作るキーボード+液晶一体型PC
    PCWatch
    Feb 11, 2026
    Lattepanda IOTA as a Roon Server on Windows
    Media Lattepanda IOTA as a Roon Server on Windows
    audiophilestyle
    Feb 20, 2026
    Análisis LattePanda IOTA Pack – El mini PC x86 más potente y versátil para IoT y automatización
    Media Análisis LattePanda IOTA Pack – El mini PC x86 más potente y versátil para IoT y automatización
    fanaticosdelhardware
    Sep 19, 2025
    Bastelboard hat sowohl Intel- als auch Raspberry-Pi-CPU
    Media Bastelboard hat sowohl Intel- als auch Raspberry-Pi-CPU
    golem.de
    Sep 18, 2025
    LattePanda IOTA is a Palm-Sized x86 SBC with Intel N150 CPU
    Media LattePanda IOTA is a Palm-Sized x86 SBC with Intel N150 CPU
    androidtvbox
    Sep 18, 2025
    LattePanda IOTA Palm-Sized Intel x86 SBC Is Here To Challenge Raspberry Pi 5
    Media LattePanda IOTA Palm-Sized Intel x86 SBC Is Here To Challenge Raspberry Pi 5
    hothardware
    Sep 18, 2025
    Kaj Ronny.Nilsen Dec 08, 2025
    This is a very good single board computer with an amazing number of connections and headers, and having the great RP2040 microcontroller on-board makes it a winner. Communication between the Intel N150 and the RP2040 goes through a serial port, and is very stable. Love the setup with the CPU at the back side, which makes it easy to attach cooling solutions and have top-level HATs at the same time. Love the various accessories too, so this SBC is no doubt highly recommended!
    Spencer.Espinoza Apr 13, 2026
    This has been a great single board computer, even with the small amounts of testing I have done with it! Very happy with it
    Raul.Becker Mar 26, 2026
    excellent as a jellyfin media server with the QSV transcoding support.
    Out Of Stock
