LattePanda IOTA Palm-sized x86 Single Board Computer (Intel N150, 16GB RAM / 128GB eMMC)
$215.00
SKU: DFR1227
Notice: Limited to 1 pieces per customer.
The LattePanda IOTA is a palm-sized x86 single-board computer featuring an Intel N150 processor, 16GB LPDDR5 RAM, and 128GB eMMC storage.
Purchase this product and earn 1075 reward points, which are tied to VIP membership program. Learn More >
LattePanda IOTA is a palm-sized, high-performance x86 single-board computer (SBC), engineered as a bridge between rapid prototyping and commercial deployment. As the next generation of the classic LattePanda V1, It integrates a powerful Intel Processor N150 with a versatile RP2040 co-processor, delivering a significant leap in computing power within a compact footprint. Key differentiators include its high speed LPDDR5 memory with IBECC for enhanced reliability, broad compatibility with desktop operating systems like Windows and Ubuntu, and a range of hardware configurations to meet diverse performance and budget needs. Designed for seamless system upgrades and future-proof applications, the LattePanda IOTA is the definitive choice for industrial automation, intelligent gateways, advanced robotics, and interactive digital installations.
Seamless Upgrade: Retains the classic LattePanda V1 form factor for easy project migration
Maintaining the compact design (88mm x 70mm) and interface layout of the LattePanda V1, LattePanda IOTA enables effortless upgrades nearly without mechanical redesign or enclosure modifications, significantly reducing development time and preserving project continuity.
LattePanda IOTA - Seamless Upgrade: Retains the classic LattePanda V1 form factor for easy project migration
8x Faster Performance
With the Intel Twin Lake N150 quad-core processor (up to 3.6GHz) and LPDDR5 high-speed memory, LattePanda IOTA offers 8x the CPU performance of LattePanda V1, ensuring ample performance and multitasking capability for most applications.
LattePanda IOTA Benchmark
LattePanda IOTA Faster Performance
Palm-Sized Design
Measuring only 88mm x 70mm, this compact LattePanda IOTA can be easily embedded into space-constrained applications like robots, smart terminals, and portable inspection devices—greatly expanding deployment possibilities for embedded systems at the edge.
LattePanda IOTA Palm-Size
Flexibility in Performance and Energy
LattePanda IOTA supports a configurable TDP (thermal design power) ranging from 6W to 15W, allowing you to balance power consumption and performance according to the application scenario.
  • 6W mode: Enables fanless, silent operation, suitable for noise-sensitive embedded systems or quiet environments.
  • 15W mode: Utilized with an active cooler to full performance, easily handling high-load computing tasks.
  • LattePanda IOTA Flexibility in Performance and Energy
    Rich I/O Connectivity
    LattePanda IOTA provides a practical and comprehensive set of interfaces, including 3x USB 3.2 Gen2 (10 Gbps) ports, a Gigabit Ethernet port, HDMI 2.1 and eDP dual video outputs, plus M.2 E-Key and PCIe FPC expansion interfaces, which easily meets various peripheral connections through a single board.
    LattePanda IOTA Rich I/O Connectivity
    Intel N150 + RP2040, Dual-Processor Collaboration
    Alongside the Intel N150 processor, LattePanda IOTA also integrates an RP2040 co-processor, which features a dual-core Arm Cortex-M0+, offers abundant GPIOs, and can be dedicated to real-time I/O control, sensor data acquisition, motor drive tasks, or even emulate a custom HID device. This design effectively reduces the load on the main processor and enhances system responsiveness and functional versatility.
    LattePanda IOTA Intel N150 + RP2040, Dual-Processor Collaboration
    Various Expansion Boards
    With dedicated expansion boards, the LattePanda IOTA can easily enhances its key capabilities:
  • UPS Expansion Board: A plug-and-play uninterruptible power supply. It provides up to 8 hours of runtime, auto power-on, and safe shutdown to protect the project from power loss. (Note: 18650 Batteries not included).
  • 51W PoE Expansion Board: Power the IOTA and get Gigabit data through a single Ethernet cable. Compliant with the IEEE 802.3bt standard, it's perfect for remote installations.
  • M.2 M-Key Expansion Board: Add a standard M.2 M-Key slot to the IOTA. Use it to connect a high-speed NVMe SSD for massive storage expansion or an AI accelerator card for edge computing tasks.
  • M.2 4G LTE Expansion Board: Grant the IOTA cellular network connectivity. Perfect for remote monitoring, mobile robots, and field-deployed devices. (Note: 4G LTE module and SIM card are not included).
  • LattePanda IOTA Intel N150 + RP2040, Dual-Processor Collaboration
    Recommended Accessories
    For a complete out-of-the-box experience, we highly recommend the LattePanda IOTA Accessories Kit, which includes the required heatsink, wifi modules, and other essential components.
    Important Notice
  • Heatsink Required: To ensure stable performance and prevent damage from overheating, a heatsink must be installed on the board before its first use.
  • No Operating System Included: This model does not come with a pre-installed OS. You will need to provide and install your own licensed operating system (e.g., Windows, Ubuntu).
  • Features
  • Retains the compact form factor and interface layout of the LattePanda V1
  • Intel N150 processor (up to 3.6 GHz, 4 cores / 4 threads)
  • Onboard 16GB LPDDR5 memory, supports IBECC
  • Onboard 128GB eMMC storage
  • Configurable TDP: 6 W to 15 W
  • Multi-OS support: Windows 10, Windows 11, Ubuntu
  • Rich expansion interfaces, including: 3× USB 3.2 Gen 2 (10 Gbps) ports, Gigabit Ethernet, HDMI 2.1 and eDP dual video outputs, M.2 E-Key and PCIe FPC expansion interfaces
  • Flexible expansion board options, supporting M.2 M-Key (NVMe storage expansion or AI acceleration), PoE, UPS, 4G LTE and other modules
  • Processor: Intel® Processor N150, 4C / 4T, up to 3.60 GHz
  • Memory: 16GB LPDDR5 4800MT/s with IBECC supported
  • Storage: 128GB eMMC 5.1
  • Display:
            HDMI 2.1, up to 4096 x 2160@60Hz
            eDP 1.4b, 2 Lanes, up to 1920 x 1080@60Hz
  • USB Ports:
            3x USB 3.2 Gen 2 Type A(10Gbps)
            1x USB 2.0 Pin Header
            1x USB Type-C PD 15V(Power supply only)
  • Network: 1x 1GbE RJ45 Port (Support WOL)
  • Expansion Slots:
            1x M.2 E Key 2230 Slot
            1x TF Card Slot
            1x PCIe FPC Connector
  • Co-processor: RP2040 MCU
  • GPIO & Other Features
            Up to 3x Analog Inputs
            Up to 16x Digital Input/Output
            1x UART
            1x USB 2.0
            1x PH2.0 4-Pin Connector(for power input)
            1x RTC Battery Connector
            1x DIP Switch
            1x Power Management Connector
            1x Fan Port
  • Audio: 3.5mm Microphone Headphone Combo Connector
  • Operating System: Windows 10 & 11, Ubuntu 22.04 & 24.04
  • Environment: 0~60°C; 0~80% relative humidity
  • Power Supply:
            USB Type-C: PD 15V
            PH2.0 4-Pin Connector: 10-15V DC
  • Size: 88mm x 70mm x 19mm
  • LattePanda IOTA (N150 16GB/128GB) x1
  • CR2032 3V RTC Battery x1
  • Product Manual x1
    令和に蘇るワープロ専用機?Intel N150で作るキーボード+液晶一体型PC
    Media 令和に蘇るワープロ専用機?Intel N150で作るキーボード+液晶一体型PC
    PCWatch
    Feb 11, 2026
    Lattepanda IOTA as a Roon Server on Windows
    Media Lattepanda IOTA as a Roon Server on Windows
    audiophilestyle
    Feb 20, 2026
    PCWatch
    Feb 11, 2026
    Análisis LattePanda IOTA Pack – El mini PC x86 más potente y versátil para IoT y automatización
    Media Análisis LattePanda IOTA Pack – El mini PC x86 más potente y versátil para IoT y automatización
    fanaticosdelhardware
    Sep 19, 2025
    Bastelboard hat sowohl Intel- als auch Raspberry-Pi-CPU
    Media Bastelboard hat sowohl Intel- als auch Raspberry-Pi-CPU
    golem.de
    Sep 18, 2025
    LattePanda IOTA is a Palm-Sized x86 SBC with Intel N150 CPU
    Media LattePanda IOTA is a Palm-Sized x86 SBC with Intel N150 CPU
    androidtvbox
    Sep 18, 2025
    Justin. Feb 26, 2026
    Pretty neat and easy to set up. I plugged in some USB-C power and fired this up with my computer monitor and keyboard, loaded up Ubuntu server and am cruising along. Great for a OpenClaw project box that can run from the house. Low power, I paired it with the passive cooling case.
    Matthew.hassin Jan 02, 2026
    Small and powerful. Great board to play with
    Alexander.Haslam Dec 17, 2025
    Awesome little device, a lot of power in a small form factor.. Wish I could use POE and NVME expansion at same time, but thats only a minor thing.
