Gravity: HUSKYLENS 2 - 6 TOPS LLM MCP AI Vision Sensor (20+ Models, Deploy Custom Models)
$84.90
SKU: SEN0638
Notice: Limited to 1 pieces per customer.
HUSKYLENS 2 K230 6 TOPS AI vision camera deploys custom models like YOLO on-device. Its MCP service provides contextual awareness for LLMs, enabling smart robotics.
Purchase this product and earn 849 reward points, which are tied to VIP membership program. Learn More >
HUSKYLENS 2 is a next-generation AI vision sensor designed to put powerful machine vision into the hands of every creator. It operates on a 1.6GHz dual-core processor with an integrated 6 TOPS AI accelerator, running all algorithms directly on-device for high-speed, low-latency results. Its core design centers on three key strengths: Rich AI Model Support, featuring 20+ built-in, ready-to-use algorithms, along with the flexibility to deploy custom-trained models; Flexible LLM Interaction, capable of both calling large models and providing local, real-world perception to LLMs via its built-in MCP service; and Broad Compatibility, ensuring seamless connection with a wide range of main controllers. Equipped with a replaceable 2MP camera, a vibrant 2.4-inch IPS touchscreen, microphone, speaker, and indicator lights, HUSKYLENS 2 is the definitive tool for educational robotics, interactive systems, and intelligent device prototyping.
Blazing-Fast On-Device AI with 6 TOPS of Power
At the core of HUSKYLENS 2 lies a dual-core 1.6GHz processor with an integrated 6 TOPS AI acceleration unit. This substantial computing power, combined with 1GB of RAM, enables HUSKYLENS 2 to run complex algorithms and neural networks directly on-device. This facilitates real-time processing for demanding tasks like multi-object detection and intricate pose estimation, ensuring high-speed, low-latency performance without reliance on cloud computation.
HUSKYLENS 2 - Blazing-Fast On-Device AI with 6 TOPS of Power
Start Creating Instantly with Over 20 Built-in AI Models
HUSKYLENS 2 is designed for immediate productivity. It comes pre-loaded with a diverse library of more than 20 AI models, covering a wide array of common computer vision tasks from face recognition to object tracking. This extensive collection allows users to start building projects right out of the box with minimal setup, significantly lowering the barrier to entry for AI application development.
HUSKYLENS 2 - Start Creating Instantly with Over 20 Built-in AI Models
Empowering LLMs with Contextual Awareness via MCP Service
HUSKYLENS 2 is the first AI vision sensor to feature a built-in MCP service, fundamentally changing how LLM perceives the physical world. While other camera provide raw image "snapshots," HUSKYLENS 2 delivers a structured, intelligent brief. It can inform a Large Language Model (LLM) that it sees a specific, pre-identified person performing a particular action. This endows LLMs with accurate, context-aware perception, enabling them to make smarter, more informed decisions.
HUSKYLENS 2 - Empowering LLMs with Contextual Awareness via MCP Service
Deployment of Custom Models Trained with YOLO
Beyond the built-in models, users can train their own vision models using YOLO and deploy them on HUSKYLENS 2. HUSKYLENS 2 comes with a complete set of annotation, training, and conversion tools, making it easy to create custom-trained models.
HUSKYLENS 2 - Deployment of Custom Models Trained with YOLO
Flexible Model Combination for Diverse Applications
HUSKYLENS 2 architecture supports the serial or parallel execution of multiple models. This capability enables the creation of more complex and nuanced applications. For instance, combining hand keypoint detection with object tracking can create sophisticated contactless control systems, where a gesture can initiate the tracking of a specific object. This multi-model approach allows for layered logic and more intelligent interactive behaviors.
HUSKYLENS 2 - Flexible Model Combination for Diverse Applications
Real-time Video Streaming for Monitoring and Debugging
HUSKYLENS 2 facilitates seamless data collection and image display through its real-time video streaming function. It supports both wired (USB-C) and wireless (via an optional Wi-Fi module) image transmission. This is critical for applications requiring remote monitoring, for collecting datasets to train new models, and for debugging visual applications by providing a live view of what the sensor sees.
HUSKYLENS 2 - Real-time Video Streaming for Monitoring and Debugging
Replaceable Camera Module for Any Application
HUSKYLENS 2 is equipped with a modular camera module, allowing it to easily adapt to a wide range of scenarios—from microscopic inspection to long-range monitoring. Its unmatched flexibility supports interchangeable lenses, including manual focus, microscope, and night vision modules.
HUSKYLENS 2 - Replaceable Camera Module for Any Application
Broad Compatibility with Mainstream Controllers
With standard UART and I2C interfaces, HUSKYLENS 2 ensures seamless connectivity with a wide range of microcontrollers and single-board computers, including Arduino, micro:bit, Raspberry Pi, ESP32, UNIHIKER K10, and UNIHIKER M10.
HUSKYLENS 2 - Broad Compatibility with Mainstream Controllers
Master Every Feature with the Massive Tutorial Wiki
HUSKYLENS 2 is supported by an incredibly detailed tutorial wiki that covers every single feature. This resource provides step-by-step walkthroughs for all 20+ models, advanced parameter tuning, and specific code and graphical programming examples for Arduino, Raspberry Pi, micro:bit, and UNIHIKER.
  • Beginner Setup: Powering on and changing the language.
  • Per-Function Deep Dives: Detailed guides for face recognition, object tracking, line tracking, OCR, and all other functions.
  • Advanced Control: Settings like detection thresholds, NMS thresholds, and custom names.
  • Model Management: How to import and export trained models for backup or sharing.
  • Model Hub for Ready-to-Use Vertical Models (Coming Soon)
    To further accelerate development, a Model Hub will be launched. This online platform will host a curated collection of official and user-generated models tailored for specific vertical markets, such as agriculture, retail, and safety monitoring. Users will be able to browse, download, and deploy these specialized models directly to their HUSKYLENS 2, providing instant access to powerful, niche AI capabilities.
    HUSKYLENS 2 - Model Hub for Ready-to-Use Vertical Models
    Video: HUSKYLENS 2 AI Vision Sensor Introduction & Demos
    Selection Guide
    HUSKYLENS 1 vs HUSKYLENS 2: The Ultimate Comparison
    Figure
    SKU
    SEN0638
    SEN0305
    Product Positioning
    Advanced Edge AI & Robotics
    Entry-level STEM Education
    AI Processor
    K230 (Dual-Core 1.6GHz)
    K210 (400MHz)
    AI Compute Power
    6 TOPS (Trillions of Operations Per Second)
    Basic Edge AI
    Built-in Models
    20+ Algorithms (Plus Hand Gestures, Pose Estimation, etc.)
    6 Algorithms (Face, Tracking, Color, Line, Tag, Object)
    Custom Models
    Advanced YOLO Deployment (Run Your Own Neural Networks)
    Basic Classification (Simple Object Training)
    LLM Integration
    MCP Support (Model Context Protocol)
    N/A
    Display & Control
    2.4" Touch Screen (High-Res IPS)
    2.0" Screen + Scroll Wheel
    Camera Lens
    Replaceable Module (Standard / Microscope / Night Vision)
    Fixed Lens
    Connectivity
    Wired + Wi-Fi 6 (Optional Module)
    Wired Only (UART / I2C)
    Add to Cart
  • Educational robotics
  • Interactive systems
  • Intelligent device prototyping
  • Processor: Kendryte K230 Dual-Core 1.6GHz
  • AI Computing Power: 6 TOPS
  • Memory: 1GB LPDDR4
  • Storage: 8GB eMMC
  • Image Sensor: GC2093, 2MP, 1/2.9", 60FPS
  • Display: 2.4" IPS Touch Screen (640×480), Full-Lamination
  • Buttons: 1 × Function Button
  • Fill Lights: 2 × LEDs
  • RGB Indicator: 1 × RGB LED
  • Wi-Fi: 2.4GHz Wi-Fi 6 (Slot-in Module)
  • Expandable Storage: 1 × TF Card Slot
  • Microphone: Capacitive Silicon Microphone
  • Speaker: 1W Acoustic Speaker
  • Operating Voltage: 3.3–5V
  • Power Consumption: 1.5–3W
  • Dimensions: 70 × 58 × 19mm
  • Net Weight: 90g
  • Interfaces: Type-C, Gravity (I2C / UART), TF Card Slot
  • HUSKYLENS 2 AI Vision Sensor x1
  • M3 Screws x6
  • M3 Nuts x6
  • Mounting Bracket x1
  • Heightening Bracket x1
  • Gravity-4P Sensor Connector Cable (30cm) x1
  • Dual-Plug PH2.0-4P Silicone Cable (20cm) x1
  • Power Adapter Board x1
    Building a Pose Recognition Robot Using HUSKYLENS 2
    Projects Building a Pose Recognition Robot Using HUSKYLENS 2
    auroraAA
    Feb 12, 2026
    Creating a Marionette Powered by HUSKYLENS 2 Hand Recognition
    Projects Creating a Marionette Powered by HUSKYLENS 2 Hand Recognition
    auroraAA
    Feb 05, 2026
    Using HUSKYLENS 2 Hand Recognition to Play Angry Birds
    Projects Using HUSKYLENS 2 Hand Recognition to Play Angry Birds
    auroraAA
    Feb 05, 2026
    Beyond the Specs: Why We Built HUSKYLENS 2 (And Should You Upgrade?)
    Blog Beyond the Specs: Why We Built HUSKYLENS 2 (And Should You Upgrade?)
    Jan 27, 2026
    DFRobot Launches HUSKYLENS 2: An Easy-to-Use AI Camera with Self-Training and Built-in MCP for LLM Connection
    Media DFRobot Launches HUSKYLENS 2: An Easy-to-Use AI Camera with Self-Training and Built-in MCP for LLM Connection
    businesspartnermagazine
    Oct 30, 2025
    Getting Started with HUSKYLENS 2 and Arduino/ESP32
    Media Getting Started with HUSKYLENS 2 and Arduino/ESP32
    Makerguide
    Nov 03, 2025
    Mervan.Tekin Dec 26, 2025
    Looking forward to create amazing projects with it. İt was very fast delivery and packaging was amazing
    francesco.sampietro Dec 11, 2025
    very nice product, it's very good
