The Gravity: 8*8 64-Pixel Matrix Time-of-Flight (ToF) Sensor is a compact and efficient 3D depth-sensing solution that bridges the gap between simple distance sensors and complex depth cameras. Powered by onboard firmware running on an RP2040 microcontroller, it delivers real-time depth data across an 8×8 matrix of 64 points within a 60° field of view, with a detection range of up to 3.5 meters. Featuring low power consumption and plug-and-play compatibility, it is well-suited for robotics, interactive art, gesture recognition, and smart automation. With support for Arduino, micro:bit, ESP32, Raspberry Pi, and LattePanda, it enables the development of advanced applications such as intelligent obstacle avoidance, contactless gesture control, and immersive interactive installations.
Figure: DFRobot 8x8 64-Pixel Matrix ToF Sensor provides intelligent obstacle avoidance for robots
3D Depth Perception at the Perfect Balance Point
This 3D robot obstacle avoidance sensor bridges the gap between basic ultrasonic sensors and high-cost AI depth cameras. Instead of seeing a single point, it generates a 64-pixel depth map that provides context—the obstacle, the open path, the edge of a table. This enables smooth, intelligent navigation without the complexity and processing demands of advanced cameras. With affordable pricing and ultra-low power usage, it offers the “just right” level of 3D vision for a wide range of creative projects.
Unmatched Compatibility for Maker Projects
This Matrix ToF proximity sensor was built for the way makers work, designed to connect to virtually anything in the workshop.
Figure: Supported Platforms of DFRobot 8x8 64-Pixel Matrix ToF Sensor
Expandable Platform for Advanced Development
In addition to plug-and-play use, the 64-Pixel Matrix ToF Vision Sensor can serve as a flexible development platform. Its onboard RP2040 processor allows developers to load custom firmware or run lightweight machine learning models (TinyML), making it possible to recognize specific gestures, detect movement patterns, or add new features directly on the sensor itself. With open-source schematics and comprehensive documentation, the module can be tailored for advanced robotics, IoT, and AI-driven applications, offering far more than a fixed-function sensor.
Figure: DFRobot 8x8 64-Pixel Matrix ToF Sensor onboard RP2040 processor
Version Update & Mixed Shipment Notification
Please Note: This product is currently undergoing a version upgrade to meet enhanced safety standards and improve firmware stability. During this transition period, new and old versions will be shipped randomly.
Update Details:
Figure: Hardware Upgrade of Gravity: 8*8 64-Pixel Matrix Time-of-Flight (ToF) Sensor
Sensor Parameters
Power Supply Parameters
Data Interface
Dec 11, 2025
very nice product, it's very good
Nov 16, 2025
For mis first buying experience all good.
