Gravity: 8x8 Matrix ToF 3D Distance Sensor (I2C&UART, 3.5m Range, 60° FOV)
$22.00
SKU: SEN0628
  • $21.50 3+ items
  • $21.00 5+ items
  • $20.00 10+ items
A 64-pixels (8x8) matrix Time-of-Flight (ToF) distance sensor module. It provides real-time depth data for 64 pixels over a 90° field of view up to 3.5 meters.
Purchase this product and earn 220 reward points, which are tied to VIP membership program. Learn More >
The Gravity: 8*8 64-Pixel Matrix Time-of-Flight (ToF) Sensor is a compact and efficient 3D depth-sensing solution that bridges the gap between simple distance sensors and complex depth cameras. Powered by onboard firmware running on an RP2040 microcontroller, it delivers real-time depth data across an 8×8 matrix of 64 points within a 60° field of view, with a detection range of up to 3.5 meters. Featuring low power consumption and plug-and-play compatibility, it is well-suited for robotics, interactive art, gesture recognition, and smart automation. With support for Arduino, micro:bit, ESP32, Raspberry Pi, and LattePanda, it enables the development of advanced applications such as intelligent obstacle avoidance, contactless gesture control, and immersive interactive installations.
DFRobot 8x8 64-Pixel Matrix ToF Sensor provides intelligent obstacle avoidance for robots
Figure: DFRobot 8x8 64-Pixel Matrix ToF Sensor provides intelligent obstacle avoidance for robots
3D Depth Perception at the Perfect Balance Point
This 3D robot obstacle avoidance sensor bridges the gap between basic ultrasonic sensors and high-cost AI depth cameras. Instead of seeing a single point, it generates a 64-pixel depth map that provides context—the obstacle, the open path, the edge of a table. This enables smooth, intelligent navigation without the complexity and processing demands of advanced cameras. With affordable pricing and ultra-low power usage, it offers the “just right” level of 3D vision for a wide range of creative projects.
Unmatched Compatibility for Maker Projects
This Matrix ToF proximity sensor was built for the way makers work, designed to connect to virtually anything in the workshop.
  • Supported Platforms: Arduino, micro:bit, ESP32, Raspberry Pi, LattePanda, UNIHIKER K10.
  • Supported Programming Methods: Whether using the Arduino IDE, or graphical editors like Mind+ and MakeCode, libraries and tutorials are available.
  • Connection Options: Support Gravity-I2C / UART / USB-C.
  • Cascading Support: The 4 switchable I2C addresses let you daisy-chain up to four sensors together for a massive field of view.
  • Supported Platforms of DFRobot 8x8 64-Pixel Matrix ToF Sensor
    Figure: Supported Platforms of DFRobot 8x8 64-Pixel Matrix ToF Sensor
    Expandable Platform for Advanced Development
    In addition to plug-and-play use, the 64-Pixel Matrix ToF Vision Sensor can serve as a flexible development platform. Its onboard RP2040 processor allows developers to load custom firmware or run lightweight machine learning models (TinyML), making it possible to recognize specific gestures, detect movement patterns, or add new features directly on the sensor itself. With open-source schematics and comprehensive documentation, the module can be tailored for advanced robotics, IoT, and AI-driven applications, offering far more than a fixed-function sensor.
    DFRobot 8x8 64-Pixel Matrix ToF Sensor onboard RP2040 processor
    Figure: DFRobot 8x8 64-Pixel Matrix ToF Sensor onboard RP2040 processor
    Version Update & Mixed Shipment Notification
    Please Note: This product is currently undergoing a version upgrade to meet enhanced safety standards and improve firmware stability. During this transition period, new and old versions will be shipped randomly.
    Update Details:
  • Hardware Upgrade (Eco-friendly & Safe): To comply with EN71 standards, the original yellow copper spacers and silver/copper thumb screws have been upgraded to black aluminum versions. This change significantly reduces lead content, making the component more environmentally friendly and safer to handle.
  • Firmware Upgrade (V1.3): The firmware has been updated from V1.2 to V1.3. This update resolves a bug where invalid distance values would remain fixed (unchanged) when the target exceeded the measurement range.
  • Hardware Upgrade of Gravity: 8*8 64-Pixel Matrix Time-of-Flight (ToF) Sensor
    Figure: Hardware Upgrade of Gravity: 8*8 64-Pixel Matrix Time-of-Flight (ToF) Sensor
  • Robotics Navigation: Smooth obstacle avoidance and drop-off detection.
  • Gesture Control: Reliable contactless interaction for smart devices.
  • Interactive Installations: Artistic displays such as “following eyes” or reactive lighting.
  • Smart Automation: Directional entryway monitoring and intelligent room sensing.
    Sensor Parameters
  • Sensor Model: VL53L7CX
  • Algorithm Processing MCU: RP2040
  • Number of Matrices: 8×8, totaling 64 ranging points
  • Ranging Mode: Continuous Ranging
  • Ranging Speed: 15Hz - 60Hz
  • Ranging Range: 20mm - 3500mm
  • Ranging Accuracy:
  • Within the range of 20 - 200mm: ±11mm for white targets, ±12mm for light gray targets, and ±12mm for gray targets;
  • Within the range of 200 - 3500mm: ±5% for white targets, ±6% for light gray targets, and ±6% for gray targets.
  • Ranging Angle: 60° horizontal, 60° vertical, 90° diagonal
  • Laser Safety Class: Compliant with Class 1 laser safety standards
  • Power Supply Parameters
  • Operating Voltage: 3.3V - 5V
  • Operating Current: Less than 80mA
  • Data Interface
  • Data Interface: I2C/UART/USB
  • Interface Type: PH2.0-4P (Gravity Pinout)
  • I2C Address: 4 adjustable options: 0x30/0x31/0x32/0x33
  • UART Baud Rate: 115200bps (fixed value, non-modifiable)
  • Firmware Update: TYPE-C, USB flash drive mode
  • Gravity: Matrix Laser Ranging Sensor ×1
  • PH2.0-4P Connection Cable ×1
  • Aluminum Alloy Mounting Bracket ×1
  • Aluminum Alloy Support Bracket ×1
  • M3 Thumb Screw ×4
  • M3 Sensor Fixing Screw ×2
  • M3×35 Mounting Copper Spacer ×2
    DIY Smart Interactive Eyes: Human Tracking & Blink Animation with ESP32-C5 (Arduino Tutorial)
    Projects DIY Smart Interactive Eyes: Human Tracking & Blink Animation with ESP32-C5 (Arduino Tutorial)
    auroraAA
    Nov 13, 2025
    John.Oliver Jul 09, 2026
    I'm still working on getting the most out of this, but I have worked through all of the functionality. It's not just that it does what it says it does that makes this sensor so good. It's the data that it produces. It gives a grid of data for all 64 points which is rather rich. Better than that though, it is fast and very accurate. I'm using a Pi 02W to operate it and I'm working on a system which will analyse the data as it flows and I can pattern match the movement directionally. There will be two of these at the front of my property and I will be able to see when a person enters the proprty, where they start from and the direction(s) that they walk in. The sensor itself doesn't give me all of that, the Pi does, but I couldn't achieve that without the rich, fast, accurate data flow. I cannot find a similar sensor at this price which can do this well.
    John.Oliver Aug 07, 2026
    I bought two of these sensors for experimental presence and obstacle detection with a Raspberry Pi Zero W. The hardware and basic integration have been good. Both sensors can operate on the same I²C bus using different selectable addresses, and I was able to read independent 8×8 distance matrices from both in a single Python process. The onboard RP2040 appears to take care of much of the low-level sensor handling, which makes the module considerably easier to experiment with than a bare ToF array. At short indoor distances, the sensors detect nearby objects clearly and provide useful spatial information rather than just a single distance value. They are particularly interesting for projects where you want to detect which part of an area has changed, rather than merely whether something is present. There are important limitations, however. In my outdoor testing, direct daylight caused most cells to report the maximum distance, with little or no response even when a person walked beneath the sensors. Performance improved in a more sheltered position, but remained much less reliable than the indoor results. Infrared illumination from security cameras may also interfere with this type of sensor at night, so placement and surrounding equipment need to be considered carefully. The 60-degree field of view and quoted maximum range should not be interpreted as guaranteed detection across the whole cone. Object material, angle, reflectivity, ambient infrared light and the size of the target all make a substantial difference. Dark, angled or partly transparent objects may appear in fewer cells than expected. Overall, I think this is a very useful and enjoyable development sensor, especially for indoor experimentation, short-range mapping and zone-change detection. It is easy to connect, supports multiple units on one bus and produces much richer data than a conventional single-point distance sensor. I would not recommend relying on it as a primary outdoor human-presence detector without extensive testing in the intended lighting conditions.
    Chih.Kuo Jul 21, 2026
    Excellent product!!!
