New: seeMote Cube for visionOS Developers - Build physical input for Apple Vision Pro apps. Learn More ›
Industrial-Grade RS485 Water Quality ORP Sensor (ModBus-RTU, IP68)
$179.00
SKU: SEN0709
  • $173.00 3+ items
  • $170.00 5+ items
  • $165.00 10+ items
Monitor water quality effortlessly with this industrial-grade RS485 ORP sensor. Features IP68 waterproofing, automatic temperature compensation, and ModBus-RTU support for Arduino and PLCs. Factory calibrated and ready to deploy.
Purchase this product and earn 1790 reward points, which are tied to VIP membership program. Learn More >
This industrial-grade Water Quality ORP (Oxidation-Reduction Potential) sensor is engineered for precise and reliable water quality analysis. Featuring an integrated probe and housing design, the sensor delivers a streamlined solution for measuring ORP values ranging from -1999 to 1999mV, with a resolution of 1mV and an accuracy of ±5mV.
Overview of Industrial-Grade RS485 Water Quality ORP Sensor (ModBus-RTU, IP68)
Designed for seamless integration into various monitoring networks, the sensor is equipped with an RS485 communication interface supporting the standard ModBus-RTU protocol. Comprehensive compatibility tutorials for Arduino development boards and DFRobot LoRaWAN systems are available, enabling rapid setup of testing environments and real-time data acquisition.
Measurement data of Industrial-Grade RS485 Water Quality ORP Sensor (ModBus-RTU, IP68)
To guarantee highly accurate and consistent data across fluctuating environmental conditions, the sensor incorporates a built-in temperature sensor with automatic temperature compensation. Each unit undergoes rigorous factory calibration, ensuring it is ready for immediate deployment without the need for initial calibration. For long-term maintenance, two-point electrode calibration is supported via register settings to optimize measurement accuracy over prolonged use. Boasting an IP68 waterproof rating, the sensor is built for continuous submersion, making it highly effective for demanding applications.
Important Maintenance Note: The probe's protective cap contains a specialized preservation liquid (3.3mol/L KCl). Even when sealed tightly, minor seepage around the cap may occur, resulting in the formation of white crystalline deposits. This is a normal physical phenomenon indicating that the probe is well-preserved. It does not compromise the sensor's lifespan or accuracy. The crystals can simply be dissolved back into the protective liquid within the cap.
  • Broad Measurement Range: Accurately reads from -1999 to 1999 mV with ±5 mV accuracy and 1 mV resolution.
  • Industrial Durability: Integrated probe and housing with an IP68 waterproof rating, rated for continuous underwater operation.
  • Automatic Temperature Compensation: Built-in temperature sensor ensures stable and reliable measurements regardless of environmental fluctuations.
  • Standardized Communication: Features an RS485 interface utilizing the standard ModBus-RTU protocol for seamless industrial IoT integration.
  • Ready to Deploy: Factory calibrated for immediate use; supports simple two-point electrode calibration for long-term accuracy maintenance.
  • Swimming pool disinfection monitoring
  • Aquaculture water quality management
  • Wastewater and effluent treatment plants
  • Environmental monitoring systems
  • Applications of Industrial-Grade RS485 Water Quality ORP Sensor (ModBus-RTU, IP68)
  • Power Supply Voltage: 10~30V DC
  • Power Consumption: 0.4W
  • Communication Interface: RS485 (Standard ModBus-RTU protocol)
  • Measurement Range:
             ORP: -1999~1999mV
             Temperature: 0°C~+60°C
  • Measurement Accuracy:
             ORP: ≤±5mV (at 25℃, in 222mV standard solution)
             Temperature: ±0.5°C
  • Resolution:
             ORP: 1mV
             Temperature: 0.1°C
  • Temperature Compensation Range: 0°C~+60°C
  • Response Time: <1S
  • Operating Temperature: 0°C~+80°C
  • Waterproof Rating: IP68
  • Pressure Resistance: 0.6MPa
  • Cable Length: 5m
  • Housing Material: Corrosion-resistant plastic
  • RS485 Water Quality ORP Sensor x1
  • 5m sensor cable x1
  • Electrode protective solution 100ml (3.3mol/L KCl) x1
  • Black protective mesh x1
  • Cable ties x2
    Building a Continuous Water Quality Monitoring System? Meet the New RS485 Sensor Series
    Blog Building a Continuous Water Quality Monitoring System? Meet the New RS485 Sensor Series
    May 13, 2026
    How to Choose the Right ORP Sensor: From Maker Projects to Industrial IoT
    Blog How to Choose the Right ORP Sensor: From Maker Projects to Industrial IoT
    Apr 08, 2026
    Antonino.Spoltore Jun 05, 2026
    Ok it works very well
