Gravity: Digital Piezo Disk Vibration Sensor
$4.50
SKU: DFR0052
  • $4.40 2+ items
  • $4.20 5+ items
  • $4.10 10+ items
Analog piezoelectric vibration sensor measures vibration extent with voltage output. Features include a wide voltage range, high-quality connector, and simple interface.
The DFRobot Vibration Sensor buffers a piezoelectric transducer that responds to strain changes by generating a measurable output voltage change which is propotional with the strength of vibration. So you can know the extent of vibration. Different from digital vibration sensor that only accounts times, this analog one can tell extent of vabiration.
  • Supply Voltage: 3.3V to 5V
  • Interface: Analog
  • Size:22x30mm (0.87x1.2'')
Improvement List
  • Standard assembling structure (Times-of-5mm Center distance between two 3mm mounting holes)
  • High quality connector
  • Immersion gold surface
Arduino can sense the pressure on piezoelectric unit.
  • Piezo Disk Vibration Sensor    x1
  • Analog cable x1
Sam . Jan 17, 2023
DFRobot has really cool products, easy to use!
Ohsoo. Feb 24, 2021
Ohsoo. Jan 19, 2021
