4 Channel Relay Shield for Arduino UNO
$13.99
SKU: DFR0144
  • $13.40 3+ items
  • $13.20 5+ items
  • $12.70 10+ items
This 4-channel relay shield for Arduino UNO controls high-power devices, featuring optocoupler isolation, XBee interface, and supports IoT integration.
Purchase this product and earn 140 reward points, which are tied to VIP membership program. Learn More >
This is a 4-channel optpcoupler-isolated relay Arduino UNO Shield, capable of controlling high-power devices operating at AC 240V 5A or DC 24V 5A for each channel.
In a home automation project, relay modules play a crucial role in managing devices such as lights, pumps, garage doors, speakers, power outlets, and fans. However, traditional relay modules are burdened by space requirements, intricate wiring, and a potential for unreliable operation. Moreover, low-quality relay modules lacking optocoupler isolation compromise the safety of the entire project.
By adopting the Arduino Shield approach, this product not only eliminates the need for complex wiring but also provides a substantial boost to project reliability. Through the integration of a 4-channel relay, it enables an Arduino UNO mainboard to exercise comprehensive control over a diverse range of devices.
4 channel relay shield for arduino
Furthermore, this expansion board boasts an XBee interface in addition to 14 3-pin digital ports and 6 3-pin analog ports. With the inclusion of the XBee interface, users have the freedom to integrate wireless modules like Bluetooth, WiFi, or Zigbee, unlocking a realm of advanced capabilities such as IoT integration, seamless smart home integration, convenient mobile control, and efficient coordination among multiple devices.
arduino uno relay shield boasts an XBee interface
Arduino Uno Relay Shield Boasts an XBee Interface
With its 4-channel optocoupler isolation and independent power supply features, this relay expansion board effectively isolates the electrical connection between AC and DC, guaranteeing the utmost electrical safety. This meticulous design effectively eliminates any potential electromagnetic interference, thereby safeguarding the Arduino mainboard from the perils of high-voltage electrical signals and mitigating the risk of damage.
  • Compatible with Arduino UNO Rev3
  • Each Relay has its own test button to test the connection
  • Standard DFRobot 3 Pin out
  • XBee I/O direct control
arduino 4 channel relay shield applications
  • 4 buttons to test module
  • LED status indicator of relay
  • Support Xbee IO directly control
  • Xbee socket for wireless communication
  • Selectable digital IO pin for control (Default digital 2,7,8,10)
  • 6 channels Analog IO & 13 channels Digital IO
  • Up to 4 Relay with photo-coupled circuit
  • Contact Rating  3A AC 120V / DC 24V
  • Max Switching Voltage  AC 240V / DC 60V (Less than 38V is recommended)
  • Max Switching Current  5A
  • Max Switching Power  AC 360VA / DC 90W
  • Electrical Life (Min)  100,000 Operations
  • Mechanical Life (Min)  10,000,000 Operations
  • Safety Standard(relay)  UL cUL TUV CQC
  • Coil Working Voltage  9VDC
  • Working temperature  -30℃ to +85℃
  • Working Humidity  40% - 85%
  • Size: 95x65mm
  • Relay Shield for Arduino V2.1          x1
  • Nylon stand-off with screw               x2
Arduino UNO Project
Projects Arduino UNO Project
RiverTrue
Feb 27, 2023
DFRobot - 4 Relay Shield for Arduino
Projects DFRobot - 4 Relay Shield for Arduino
RiverTrue
Jul 22, 2022
Only 7 Left
