Romeo - a Robot Control Board with Motor Driver (Compatible with Arduino)
$24.90
SKU: DFR0004
  • $24.00 2+ items
  • $23.50 5+ items
  • $23.00 10+ items
The robot control board features integrated motor drivers, wireless communication, and compatibility with numerous sensors for easy robotics projects.
Romeo family is an All-in-One Robot control board especially designed for robotics applications from DFRobot.  It benefits from the Arduino open source platform, it is supported by thousands of open source codes, and can easily be expanded with your shields. The integrated 2 way DC motor driver and wireless socket allows you to start your own robot project immediately without the need for an additional motor driver.  Not just has the motor driver, Romeo is also designed to have extra power for servos which need more current.
Romeo is also featured with DFRobot's standard 3 Pin-out designed and compatible with Gravity series sensors and actuators. Hundreds of sensors are now plug-play with Romeo.
This is the first member in Romeo family that is born in 2009. It is not only the very first Arduino compatible robot controller but also the first Arduino-derived board in the market. The current version of Romeo is based on Arduino Uno. It has built-in 2x2A DC motor drivers and socket for bluetooth / APC220 Radio Communication Module communications. The integrated io sensor pinout allows it connect hundreds of different Gravity compatible sensors and modules. It has servo connector which is a plug & play. It is the ideal controller to build your own robot
Romeo All in One Robot Controller Board Review by Arnab Kumar Das
Tank Robot Project using the Devastator metal chassis!
  • DC Supply:USB Powered or External 7V~12V DC
  • DC Output:5V /3.3V DC and External Power Output
  • Microcontroller: Atmega328
  • Bootloader: Arduino Uno
  • Compatible with the Arduino Uno pin mapping
  • 8 Channels 10-bit Analog I/O
  • USB interface
  • 5 key inputs
  • Auto sensing/switching power input
  • ICSP header for direct program download
  • Serial Interface TTL Level
  • Support Male and Female Pin Header
  • Integrated sockets for APC220 RF Module and DF-Bluetooth Module
  • Three I2C Interface Pin Sets(two 90°pin headers)
  • Two way Motor Driver with 2A maximum current
  • Gold plating pcb board
  • Size:90x80x14mm(3.54"x3.15"x0.55")
  • Weight:60 gram
DFRobot Arduino-Compatible Microcontrollers Selection Guide
Blog DFRobot Arduino-Compatible Microcontrollers Selection Guide
Jul 30, 2020
Thushara.Rathnayake Jul 03, 2021
Very nice control board. Easy to connect all the peripherals with jumper wires. Excellent quality connections which is important when a robot is moving.
kyle.benson May 18, 2023
Very fast shipping. Thank you!
