Gravity: Digital Vibration Sensor
$2.50
SKU: DFR0027
  • $2.40 5+ items
  • $2.20 10+ items
  • $2.00 50+ items
A digital vibration sensor compatible with Arduino for detecting vibrations. It features easy programming, a wide voltage range, and high-quality connectors.
What's the simplest way to check vibration with Arduino? Use a vibration sensor from DFRobot. You can directly plug it on our IO Expansion Shield V7. Just vibrate this sensor, Arduino can receive a digital signal. It's easy to acount and program in Arduino.
Despite it's simple, you can make full use of it with creative thinking, like step counting, Crash warning light and so on.
Inprovement
  • Standard assembling structure (Times-of-5mm Center distance between two 3mm mounting holes)
  • High quality connector
  • Immersion gold surface
a simple Pedometer device that can count your step
  • IO Type: Digital
  • Switch life: up to 10 million seconds
  • Open circuit resistance: 10Mohm
  • Supply Voltage: 3.3V to 5V
  • Interface: Digital
  • Size:22x30mm (0.87 x 1.18 in)
  • Sensor x1
  • Digital Sensor Cable (SKU:FIT0011)  x1
Ivan.Pavelic Nov 27, 2025
Excellent sensor for prototype of detection stronger vibrations.
Steffen.Lorenz Jan 20, 2025
Works - But you have to shake it really hard!
Ohsoo. Feb 24, 2021
