This is a new Analog Sound Sensor compatible with Arduino. Sound Sensor is typically used in detecting the loudness in ambient, the Arduino can collect its output signal and actuate accordingly. You may use it to make some funny interactive works such as a "clap and buzz" to find your lost keys or remote control if you add a buzzer. This sensor works best with our Audio analyzer module.
As one of our new version of breakout boards, we have improved the analog sound sensor in below:
To ease the difficulty of using this analog sound sensor, a Gravity Interface is adapted to allow plug&play. The IO expansion shield is the best match for this sound senor connecting to your Arduino. This sound sensor can work at 3.3V which makes it compatible with Raspberry Pi, intel edison, joule, and curie.
Aug 20, 2025
Work fine, stable, easy to set.
Apr 10, 2025
Excellent microphone, presoldered, no fuss, as easy connection as it gets! :)
Feb 24, 2021
