Gravity: Analog Sound Sensor for Arduino
$4.40
SKU: DFR0034
  • $4.20 2+ items
  • $4.00 5+ items
  • $3.80 10+ items
This Analog Sound Sensor is compatible with Arduino, detects sound intensity, and features improved voltage range and interfaces. Suitable for DIY projects.
Purchase this product and earn 44 reward points, which are tied to VIP membership program. Learn More >
This is a new Analog Sound Sensor compatible with Arduino.  Sound Sensor is typically used in detecting the loudness in ambient, the Arduino can collect its output signal and actuate accordingly. You may use it to make some funny interactive works such as a "clap and buzz" to find your lost keys or remote control if you add a buzzer. This sensor works best with our Audio analyzer module.
As one of our new version of breakout boards, we have improved the analog sound sensor in below:
  • Standard assembling structure (two 3mm holes with multiple of 5cm as interval)
  • Icons to simply illustrate sensor function
  • High-quality connector
  • Immersion gold surface
arduino sound sensor demo project 1
Arduino sound sensor demo project 2
To ease the difficulty of using this analog sound sensor,  a Gravity Interface is adapted to allow plug&play.  The IO expansion shield is the best match for this sound senor connecting to your Arduino. This sound sensor can work at 3.3V which makes it compatible with Raspberry Pi, intel edison, joule, and curie.
  • Supply Voltage: 3.3V to 5V
  • Swift sound intensity detection
  • Interface: Analog
  • Size:22x32mm (0.87 x 1.26 in)
    • Analog Sound Sensor x1
    • Analog cable x1
    TinyML Voice Recognition: ESP32, Arduino, STM32 Hardware Compared
    Blog TinyML Voice Recognition: ESP32, Arduino, STM32 Hardware Compared
    Sep 23, 2024
    Regent. Aug 20, 2025
    Work fine, stable, easy to set.
    Mihailo.Milankovic Apr 10, 2025
    Excellent microphone, presoldered, no fuss, as easy connection as it gets! :)
    Ohsoo. Feb 24, 2021
