Search - force sensor - products, projects and tutorials - DFRobot
logo
CommunityForumWikiBlogLearn
  • $USD
  • EUR€
  • £GBP
  • . VIP
  • My Account
  • Order History
  • VIP Benefits
  • Logout
31 item(s) found for "force sensor"
  • Product(31)
  • Blog(0)
  • Wiki(33)
  • Category: ArduinoGravityModulesSensors
  • Working Voltage: 5V3.3V
  • Types of Signal: DigitalAnalog
  • Integrated Development Environment: Arduino IDEMind+
  • Programming Language: C++
  • Interface: PH2.0Pin
More Filters
Default Hot Sell New Arrival Price Price
    SKU: SEN0065
    Only 2 Left
    4mm Mini Circular Force Sensor
    $5.95
    SKU: SEN0047
    Out Of Stock
    0.5" Circular Force Sensor (100g-10kg)
    $6.90
    SKU: SEN0296
    In Stock
    Square Force Sensor (40x40mm, 20g-10kg, Thickness: 0.45mm)
    $7.90
    SKU: SEN0294
    In Stock
    Circular Force Sensor (Diameter: 18.3mm, 20g-6kg, Thickness: 0.4mm)
    $5.00
    SKU: SEN0297
    In Stock
    Circular Force Sensor (Diameter: 7.6mm, 30g-1.5kg, Thickness: 0.3mm)
    $3.00
    SKU: SEN0295
    In Stock
    Circular Force Sensor with Extended Leads (Diameter: 18.3mm, 20g-6kg, Thickness: 0.4mm)
    $6.90
    SKU: SEN0298
    In Stock
    Circular Force Sensor with Extended Leads (Diameter: 7.6mm, 30g-1.5kg, Thickness: 0.3mm)
    $3.90
    SKU: SEN0293
    In Stock
    Pressure Sensor Strip (170mm, 20g-10kg)
    $6.50
    SKU: SEN0299
    Only 7 Left
    Pressure Sensor Strip (400mm, 20g-10kg)
    $10.90
    SKU: SEN0064
    Out Of Stock
    Flex Sensor 4.5" Bend Resistor (60KΩ-110KΩ Range)
    $19.90
    SKU: SEN0160
    In Stock
    Gravity: Digital Weight Sensor
    $16.95
    SKU: SEN0086
    Only 3 Left
    Flex Sensor 2.2" Bend Resistor (10KΩ-125KΩ Range)
    $11.90
    SKU: SEN0209
    Out Of Stock
    Gravity: Flexible Piezo Film Vibration Sensor
    $5.90
    SKU: SEN0066
    In Stock
    100lb FlexiForce Pressure Sensor (Diameter: 9.53mm)
    $22.90
    SKU: DFR0029-G
    Only 12 Left
    Gravity: Digital Push Button (Green)
    $1.70
    SKU: DFR0032
    In Stock
    Gravity: Digital Buzzer for Arduino / ESP32 / micro:bit / Raspberry Pi
    $1.90
    SKU: FIT0344
    In Stock
    Nylon Cable Tie Set - With Tag (10PCS)
    $0.60
    SKU: FIT0537
    In Stock
    Magnetic Stirrer with Stir Bar
    $39.80
    SKU: SEN0138-L
    In Stock
    Gravity: Digital Crash Sensor (Left)
    $1.90
    SKU: FIT0343
    In Stock
    Nylon Cable Tie Set - Five Colors (50PCS)
    $0.60
loading……
no-result-icon
Not finding any matches, please try different keywords.
Would you like to view our new products ?
Information About UsWarrantyTerms & ConditionsShippingPaymentFAQCustomer Service DFRobot DistributorsContact UsSite MapMy Account AffiliatesSpecials
logo
Sign up for exclusive offers!
Like us on
Copyright © 2025 DFRobot. All rights reserved.
