PROJECTS micro:bit micro:bit Project 7: Music Box
Oct 15 2018 261263
In the gift shop, we can always see various eye-catching music box in different shapes which are not only cool but also interesting. This lesson to be learnt is about producing a music box. Now, let’s begin.
Components needed
Hardware Connection
Connect the mainboard of micro: bit to the computer and plug the headphone into the jack.
Connect the motion sensor module to interface P1 of the expansion board.
Note: since the jack occupies the interface P0, so P0 is not available when playing the sound.
Program
Task1: Electronic music box
Functions: enable the mainboard of micro: bit play the music.
STEP1: drag the “start melody dadadum repeating once” of the “Music” to “forever”. There are already many built-in melodies for choices. The one we chose here is the first melody "dadadum" to be repeated once.
STEP2: since the complete melody "dadadum" accounts for 4 beats, so the time range needed be set for play is 4 beats in the below module. Final procedure
STEP3: try to adjust the sound that the micro: bit board plays by turn the "turntable" next to the earphone jack on the expansion board.
Task2 : smart music box
Functions: When someone is approaching, the mainboard of micro: bit will play a piece of music that you have edited; when no one is near, it does No play any music.
STEP1:edit "Twinkle, Twinkle Little Star" .
First, look at the musical notation, tones, Noes and the vocal frequency required of the song before trying writing the code to play the first sentence of it.
Take the middle C as an example, the sound frequency and its corresponding notes are shown in the following table:
| Notes | 1 | 2 | 3 | 4 | 5 | 6 | 7 |
| Hz | 262 | 294 | 330 | 350 | 393 | 441 | 495 |
Click the “Music”, now the used module is about the “play tone Middle C for 1 beat”. Here, you can set the tone and beats.
After editing the song, we enable our micro: bit to sing, but how can it be made more smart? Now, we need to use a motion sensor. In fact, it principle is very simple. We can make the music box smart by adding a conditional statement we have learned before! Let’s study how to make come true.
STEP2:the final program
