SELECTION GUIDE LattePanda
LattePanda Alpha Delta Selection Guide
DFRobot Dec 01 2019 264163
LattePanda Alpha & Delta
Product Name
LattePanda 2 Delta 432 - (4GB RAM/32GB eMMC)
LattePanda 2 Delta 432 - (Win10 Pro Activated, 4GB/32GB)
LattePanda 2 Alpha 800s - (8GB RAM)
LattePanda 2 Alpha 864s - (8GB RAM/64GB eMMC)
LattePanda 2 Alpha 864s - (Win10 Pro Activated, 8GB/64GB)
Figure
SKU
DFR0543
DFR0544
DFR0545
DFR0546
DFR0547
Processor
Intel Celeron N4100
Intel Celeron N4100
Intel Core M3-8100Y
Intel Core M3-8100Y
Intel Core M3-8100Y
Base Frequency
1.10-2.40GHz
1.10-2.40GHz
1.10-3.40GHz
1.10-3.40GHz
1.10-3.40GHz
Graphics
Intel UHD Graphics 600 200-700MHz
Intel UHD Graphics 615 300-900MHz
Cores
4
4
2
2
2
Memory
4GB LPDDR4
4GB LPDDR4
8GB LPDDR3
8GB LPDDR3
8GB LPDDR3
eMMC
32GB
32GB
NO
64GB
64GB
Mass Storage
m.2 M Key SSD slot/ Micro SD card slot
OS
NO
Windows 10 Pro(Activated)
NO
NO
Compatible OS
Windows / Linux
Windows / Linux
Windows / Linux / Android
Arduino Co-processor
Arduino Leonardo
Arduino Leonardo
Arduino Leonardo
Arduino Leonardo
Arduino Leonardo
USB
3 x USB3.0 ports
3 x USB3.0 ports
3 x USB3.0 ports
3 x USB3.0 ports
3 x USB3.0 ports
Networking
WIFI 802.11ac/ Gigabit Ethernet LAN Interface/ m.2 E Key for optional wireless modules
Bluetooth
Bluetooth 5.0
Bluetooth 5.0
Bluetooth 4.2
Bluetooth 4.2
Bluetooth 4.2
Video Interface
HDMI / DP / eDP display
Other
2x 50p GPIOs including I2C, I2S, USB, TTL, UART, RTC,Power Management,Extendable power button
2x 50p GPIOs including I2C, I2S, USB, RS232, UART, RTC,Power Management, Extendable power button
Recommend Reasons
LattePanda Delta uses Intel 8th generation Celeron N4100 processor as a main robotics controller, interactive project core, IoT edge device or AI brain, and at the same time it’s also equipped with Arduino co-processor, compatible with Arduino hardware modules and software libraries. Delta will be your perfect choice both in terms of function and price. * Suitable for projects with high requirements on performance but with limited budget.
LattePanda Delta uses Intel 8th generation Celeron N4100 processor as a main robotics controller, interactive project core, IoT edge device or AI brain, and at the same time it’s also equipped with Arduino co-processor, compatible with Arduino hardware modules and software libraries. Delta will be your perfect choice both in terms of function and price. * Suitable for projects with high requirements on performance but with limited budget. * Suitable for business or personal projects that require a Windows License.
LattePanda Alpha uses Intel Core m3 processor, which is the same as the latest MacBook. The Core m3 processor is the perfect choice for superior performance and low power consumption, better than Delta both in graphics card performance and the maximum memory support. With its own 8GB RAM and 64GB eMMC, M.2 interface SSD support and rich GPIO extension ports, Alpha can meet most of the application needs. * Suitable for projects with high requirements on performance and computing. No eMMC storage on board. Users can install SSD and operating systems by themselves. Flexible to use.
LattePanda Alpha uses Intel Core m3 processor, which is the same as the latest MacBook. The Core m3 processor is the perfect choice for superior performance and low power consumption, better than Delta both in graphics card performance and the maximum memory support. With its own 8GB RAM and 64GB eMMC, M.2 interface SSD support and rich GPIO extension ports, Alpha can meet most of the application needs. * Suitable for projects with high requirements on performance and computing. * Suitable for business or personal projects that require a Windows License.
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Sales status
Discontinued
Discontinued
In stock
In stock
In stock
