NEWS
DFRobot Halloween Gift Guide
DFRobot Oct 17 2024 270559
Whether you’re creating spooky decorations, interactive haunted props, or lighting up your space with eerie effects, our curated selection of maker tools will inspire your next Halloween masterpiece. Explore our top picks for interactive sensors, DIY lighting, essential maker tools, and exciting project ideas to make this Halloween truly unforgettable!
Recommend Halloween Prodducts
1. Recommend Interactive Halloween Sensors
Set the stage for a haunting experience with sensors that trigger lights, sounds, and movements when your guests least expect it. Ideal for DIY Halloween projects.
Product Name
Gravity: Digital PIR (Motion) Sensor for Arduino / Raspberry Pi
Gravity: Digital 10.525GHz Microwave Sensor (Motion Detection)
mmWave Radar - 24GHz Human Presence Detection Sensor (9 Meters)
Gravity: GR10-30 Gesture Sensor (UART & I2C, 12 Gestures, 0~30cm)
Figure
SKU
SEN0171
SEN0192
SEN0395
SEN0561
Detects nearby motion precisely, great for triggering effects in simple Halloween projects.
Detects motion through objects (like decorations), perfect for more complex setups requiring subtle detection.
Covers a large detection range, ideal for hidden triggers in big spaces, even through decorations.
Trigger different lighting or sound effects with hand gestures, letting participants control the scene.
Price
$4.90
$8.90
$29.00
$23.00
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Product Name
Gravity: Huskylens - An Easy-to-use AI Camera | Vision Sensor
Gravity: Digital Piezo Disk Vibration Sensor
Gravity: Digital 360° Tilt Sensor for Arduino
Gravity: Flexible Piezo Film Vibration Sensor
Figure
SKU
SEN0305
DFR0052
DFR0830
SEN0209
Adds intelligence to projects with AI vision, great for creating interactive Halloween props with advanced recognition.
Detects subtle vibrations, perfect for hiding in doors or floors to trigger effects when someone moves through the space.
Ideal for designing physical interactive scare devices that respond to tilting or movement.
Senses flexible vibrations, great for placing on chairs or benches to trigger interactions when someone sits or moves.
Price
$54.90
$4.50
$2.50
$5.90
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
2. Halloween DIY Lighting & Display - Set the Mood with Spooky Lighting and Displays
Nothing says Halloween like eerie lighting! Whether you’re illuminating your front yard with glowing pumpkins or creating a spooky display inside, our DIY lighting kits will help you achieve the perfect haunted ambiance. From LED strips to custom light displays, you can control and customize the effects to match your Halloween vision.
Product Name
Fermion: 1.51” OLED Transparent Display with Converter (Breakout)
Digital RGB LED Strip 120 LED-Black
Flexible LED Filament (12V 600mm, 2200K)
Fermion: 2.0" 320x240 IPS TFT LCD Display with MicroSD Card (Breakout)
Figure
SKU
DFR0934
FIT0612
FIT0926
DFR0664
Creates floating images for a unique visual effect.
Perfect for colorful lighting effects over a large area.
Flexible filament for soft, flame-like lighting.
Ideal for playing looping videos in embedded setups.
Price
$34.90
$11.90
$5.90
$17.90
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Product Name
1.47" 172×320 IPS LCD Display Module
5V Remote Wireless Power Supply Lamp Pack
WS2812-24 RGB LED Ring Lamp
5V Flexible LED Strip (60 LEDs) - Green
Figure
Displays detailed patterns or text, great for small spaces.
Wireless lamps, perfect for close-up lighting effects or costumes.
Best for circular light effects or mystical symbol designs.
Creates a mysterious green atmosphere.
Price
$9.90
$9.90
$11.90
$5.90
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
3. Maker Essentials - Get Equipped with the Tools You Need for Your Halloween Projects
Every maker knows the importance of having the right tools for the job. Our maker essentials section is filled with everything you need to make your Halloween creations come to life. Whether you’re building a mechanical prop or designing a spooky interactive display, these tools will help you along the way.
Maker Essentials
Product Name
Soldering Starter Tool Set
Multi-color Block Building Breadboard Kit
Mini Illuminated Loupe 30X / Magnifier with LED Lights
28 PCS Universal 5.5*2.1mm DC Adapter Kit
Figure
SKU
KIT0077
FIT0908
FIT0400
FIT0881
Ideal for soldering LED strips or sensors for Halloween projects.
Helps quickly build and test electronic circuits.
Built-in LED for working in dark environments, perfect for night-time Halloween setups.
Provides various adapters for powering multiple Halloween devices.
Price
$35.95
$9.90
$7.50
$9.90
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Maker Essentials
Product Name
Bionic Robot Hand (Right)
Black Gladiator - Tracked Robot Chassis
Flamewheel - A 2WD Remote Control Robot
Colorful RGB LED Strip Kit (Support iPhone & Android)
Figure
SKU
ROB0143
ROB0153
ROB0139
KIT0069
Adds interactive and spooky effects to Halloween scenes.
Ideal for mobile Halloween robots with enhanced stability and terrain adaptability.
Easy to control and program for Halloween automation.
Mobile-controlled dynamic lighting for Halloween decorations.
Price
$199.00
$25.00
$39.90
$129.90
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Halloween Projects - Get Inspired by These Halloween DIY Project Ideas
Not sure where to start? Check out our collection of Halloween project ideas that you can build with the products from our store! From magic mirror to scary pumpkin, these projects are perfect for makers of all skill levels.
Halloween Projects
