NEWS DFRobotEnglish
2020 Top 10 New Products of DFRobot
DFRobot Jan 26 2021 260177
As the new year has come, we list the top 10 DFRobot new products of 2020. Let's check what those tops are!
 Top 1.   Gravity: HUSKYLENS - An Easy-to-use AI Machine Vision Sensor
Introduction: HuskyLens is an easy-to-use AI machine vision sensor. It is equipped with multiple functions, such as face recognition, object tracking, object recognition, line tracking, color recognition, and tag(QR code) recognition.
Through the UART / I2C port, HuskyLens can connect popular main control boards like Arduino, micro:bit, Raspberry Pi and LattePanda to help you make very creative projects without playing with complex algorithms.
Price: $48.40
 Top 2.   Gravity: Analog pH Sensor / Meter Pro Kit V2
Introduction: DFRobot Gravity: Analog pH meter pro V2 is specifically designed to measure the pH of the solution and reflect the acidity or alkalinity. It is commonly used in various applications such as aquaponics, aquaculture, and environmental water testing.
As an upgraded version of pH meter pro V1, the secondary generation pH meter pro greatly improves the precision and user experience. The onboard voltage regulator chip supports the wide voltage supply of 3.3~5.5V, which is compatible with 5V and 3.3V main control board, such as Arduino and LattePanda. The output signal filtered by hardware has low jitter. The software library adopts the two-point calibration method, and can automatically identify two standard buffer solutions (4.0 and 7.0), so simple and convenient. It uses an industry electrode and has built-in simple, convenient, practical connection and long life, very suitable for online monitoring.
Price: $64.90
 Top 3.   micro:Maqueen Plus - an Advanced STEM Education Robot for micro:bit
Introduction: micro: Maqueen Plus is an advanced version of micro:Maqueen Lite (4.0), which is more powerful and intelligent. Optimized with better power management and larger capacity power supply, it can be perfectly compatible with HuskyLens AI Vision Sensor, which makes it an accessible AI robot teaching tool.
In addition, micro:Maqueen Plus comes with a larger and more stable chassis, more built-in functions and more expansion ports, it is not only suitable for classroom teaching, but also can be suitable for after-school extended exercises and robot competitions.
Price: $49.90
 Top 4.   micro:Maqueen Mechanic Series
Introduction: Use this kit to change your Maqueen Lite and Maqueen Plus into a Mechanic Beetle! The Maqueen Mechanic-Beetle kit includes a metal servo, mechanical parts, screws, etc. Just a simple installation, your Maqueen car (Lite or Plus) is ready to go.
This play-and-learn kit comes with rich mechanical knowledge, which could allow students to benefit a lot from hands-on practices! Come and find more fun and interesting ways to play with Maqueen in this kit.
Price: $9.9     micro:Maqueen Mechanic - Loader
Price: $9.9     micro:Maqueen Mechanic - Push
Price: $9.9    micro:Maqueen Mechanic - Beetle
Price: $14.9    micro:Maqueen Mechanic - Forklift
 Top 5.   Gravity: AS7341 11-Channel Visible Light Sensor
Introduction: We live in a colorful world, but how much do you really know about color? Your eyes may deceive you, while the sensors don’t lie. This Gravity: AS7341 11-Channel Visible Light Sensor can tell you the truth about color.
Gravity: AS7341 11-Channel Visible Light Sensor employs the new generation of AS7341 spectral sensor IC launched by the well-known AMS company. The sensor features eight channels for the visible light, one channel for near-IR, and one channel without a filter. Also, it integrates a dedicated channel to detect ambient light flicker. Besides that, this sensor comes with 6 independent 16-bit ADC channels for data processing in parallel. The two on-board extra-bright LEDs can supply light in a dark environment.
Price: $17.5
 Top 6.   Gravity: Analog Waterproof Capacitive Soil Moisture Sensor
Introduction: This is a new type of analog capacitive soil moisture sensor designed by DFRobot. Compared with the old soil moisture sensor, it has increased waterproof performance. Even if the sensor is fully immersed in water, it can still be used normally; the anti-corrosion performance is optimized and more Laminate design, no longer need to worry about the sensors in the soil scratching the sensor panel, resulting in accelerated corrosion of the sensor; the length of the electrode plate is increased and the circuit performance is optimized, the measurement range is expanded, and the measurement value of the sensor is more accurate!
Price: $14.9
 Top 7.   SHT31 Weather-proof Temperature & Humidity Sensor
Introduction: This is an SHT31 Temperature & Humidity sensor housed in a weather-proof enclosure. The sensor is designed to be waterproof so you can use it safely in outdoor projects. Please note that although the sensor is waterproof, it is not suggested to submerge it in water. For in-water measurement, the DS18B20 Sensor is highly recommended.
Price: $19.9
 Top 8.   DFRobot MAX30102 Heart Rate and Oximeter Sensor Breakout Board
Introduction:
The MAX30102 is integrated pulse oximetry and heart-rate monitor biosensor module based on PPG ((PhotoPlethysmoGraphy). It is so small that you can just wear it on your finger or wrist for data collecting. Internally integrated 18bit ADC, the sensor supports I2C data output, which could be compatible with most controllers.
Price: $9.9
 Top 9.   Gravity: I2C Oxygen Sensor
Introduction:
The Gravity: I2C Oxygen Sensor is based on electrochemical principles and it can measure the ambient O2 concentration accurately and conveniently. With high anti-interference ability, high stability, and high sensitivity, this Arduino-compatible oxygen sensor can be widely applied to fields like portable device, air quality monitoring device, and industries, mines, warehouses, and other spaces where the air is not easy to circulate.
Price: $53.90
 Top 10.   Gravity: Capacitive Fingerprint Sensor
Introduction:
This is a capacitive fingerprint sensor with fingerprint collecting, processing, storing, and comparison integrated all-in-one. Taking ID809 high-performance processor and semiconductor fingerprint sensor as the core, the sensor is equipped with built-in IDfinger6.0 fingerprint algorithms that enable it to complete all the fingerprint recognition independently. When working with our Arduino Library, the module is able to realize functions like fingerprint registration, fingerprint deletion, etc. Also, we offer upper computer software to help users conveniently operate this sensor.
Price: $24.90
