NEWS DFRobotEnglish
2022 Top 10 New Products
DFRobot Jan 10 2023 262813
Thank you very much for your support and advice in 2022!
As the new year has come, we list the top 10 DFRobot new products of 2022. Let's check what those tops are!
LattePanda 3 Delta 864
1
 The Fastest Pocket-sized Windows/Linux Single Board Computer
Document .bt{ border: none; /* */ background: #0000FF; /* */ color: white; /* */ */ font-size: 28px; /* */ padding: 20px; /* */ width: 150px; /* */ border-radius: 20px; /* */ } .bt span{ transition: 0.5s; /* */ } .bt:hover span{ padding-right: 25px; /* */ } .bt span:after{ content: "»"; /* */ opacity: 0; /* */ transition: 0.5s; /* */ } .bt:hover span:after{ opacity: 1; /* */ } $279.00
LattePanda 3 Delta is poised to define a new era of computing and drive mega creativity for tech enthusiasts and industry innovations.
It gets a significant performance boost by upgrading from the Celeron N4100 of the LattePanda Delta to the Intel 11th-generation Celeron N5105 processor with up to 2.9GHz burst frequency, maintaining almost the same pinout and layout as the previous version to allow for effortless system migration or upgrading by replacement. Compared to its previou version, the CPU of LattePanda 3 Delta speeds up to 2 x faster while the GPU speeds up to 3 x faster to support usage like playing a 4K HDR video and running heavy games.
Gravity: 2-Channel I2C DAC Module (0-10V)
2
 Designed for Industrial Application
Document .bt{ border: none; /* */ background: #0000FF; /* */ color: white; /* */ */ font-size: 28px; /* */ padding: 20px; /* */ width: 150px; /* */ border-radius: 20px; /* */ } .bt span{ transition: 0.5s; /* */ } .bt:hover span{ padding-right: 25px; /* */ } .bt span:after{ content: "»"; /* */ opacity: 0; /* */ transition: 0.5s; /* */ } .bt:hover span:after{ opacity: 1; /* */ } $9.90
This 2-Channel I2C DAC module can output a voltage of 0-10V, which is a standard driver in industrial applications.
It can be widely used with most 0-10V devices on markets such as light controllers, inverters, valves, pumps, etc, by Arduino programming.
3
 RISC-V Core Development Board
Beetle ESP32 - C3
Document .bt{ border: none; /* */ background: #0000FF; /* */ color: white; /* */ */ font-size: 28px; /* */ padding: 20px; /* */ width: 150px; /* */ border-radius: 20px; /* */ } .bt span{ transition: 0.5s; /* */ } .bt:hover span{ padding-right: 25px; /* */ } .bt span:after{ content: "»"; /* */ opacity: 0; /* */ transition: 0.5s; /* */ } .bt:hover span:after{ opacity: 1; /* */ } $7.90
Beetle ESP32-C3, mainly intended for IoT applications, is a controller based on ESP32-C3 RISC-V 32bit single-core processor.
On a coin-size board of 25*20.5 mm, there are up to 13 IO ports broken out, so you don't have to worry about running out of IO ports when making projects.
Self-powered Wireless Switch (433Mhz)
4
 Can Send Signals Wirelessly Without Battery
Document .bt{ border: none; /* */ background: #0000FF; /* */ color: white; /* */ */ font-size: 28px; /* */ padding: 20px; /* */ width: 150px; /* */ border-radius: 20px; /* */ } .bt span{ transition: 0.5s; /* */ } .bt:hover span{ padding-right: 25px; /* */ } .bt span:after{ content: "»"; /* */ opacity: 0; /* */ transition: 0.5s; /* */ } .bt:hover span:after{ opacity: 1; /* */ } $8.90
This self-powered wireless switch from DFRobot can send signals wirelessly without installing a battery.
The switch is composed of a micro-generator and a 433Mhz radio frequency circuit.
Fermion: 1.51” OLED Transparent Display with Converter (Breakout)
5
 Full-view Transparent OLED Display
Document .bt{ border: none; /* */ background: #0000FF; /* */ color: white; /* */ */ font-size: 28px; /* */ padding: 20px; /* */ width: 150px; /* */ border-radius: 20px; /* */ } .bt span{ transition: 0.5s; /* */ } .bt:hover span{ padding-right: 25px; /* */ } .bt span:after{ content: "»"; /* */ opacity: 0; /* */ transition: 0.5s; /* */ } .bt:hover span:after{ opacity: 1; /* */ } $34.90
This is a 1.51” SSD1309 transparent monochrome OLED display (light blue) with a converter. It offers a resolution of 128×64 (The completely transparent area is 128×56.
There is a small section near the pins that are not transparent but still can display content), full-view, and blue display.
Gravity: Geiger Counter Module Ionizing Radiation Detector
6
Document .bt{ border: none; /* */ background: #0000FF; /* */ color: white; /* */ */ font-size: 28px; /* */ padding: 20px; /* */ width: 150px; /* */ border-radius: 20px; /* */ } .bt span{ transition: 0.5s; /* */ } .bt:hover span{ padding-right: 25px; /* */ } .bt span:after{ content: "»"; /* */ opacity: 0; /* */ transition: 0.5s; /* */ } .bt:hover span:after{ opacity: 1; /* */ } $60.00
The Geiger counter can only detect ionizing radiation, such as nuclear radiation, X-rays, cosmic rays, etc.
In addition, the Geiger counter is a good random number generator, and undetermined high-energy particle ionization events can provide enough random entropy to get you a truly random number, rather than a fixed random sequence based on a random algorithm.
Gravity: ENS160 Air Quality Sensor
7
 Designed for Indoor Air Quality Monitoring
Document .bt{ border: none; /* */ background: #0000FF; /* */ color: white; /* */ */ font-size: 28px; /* */ padding: 20px; /* */ width: 150px; /* */ border-radius: 20px; /* */ } .bt span{ transition: 0.5s; /* */ } .bt:hover span{ padding-right: 25px; /* */ } .bt span:after{ content: "»"; /* */ opacity: 0; /* */ transition: 0.5s; /* */ } .bt:hover span:after{ opacity: 1; /* */ } $19.90
This Gravity: ENS160 Air Quality Sensor, based on ScioSense's new ENS160 sensor chip, is specifically designed for indoor air quality monitoring and offers detection of multiple IAQ data (TVOC, eCO2, AQI).
Gravity: Factory Calibrated Electrochemical Oxygen Sensor (0-25%Vol, I2C & UART)
8
 Factory Calibrated
Gravity: Electrochemical Oxygen Sensor (0-25%Vol, I2C & UART)
Document .bt{ border: none; /* */ background: #0000FF; /* */ color: white; /* */ */ font-size: 28px; /* */ padding: 20px; /* */ width: 150px; /* */ border-radius: 20px; /* */ } .bt span{ transition: 0.5s; /* */ } .bt:hover span{ padding-right: 25px; /* */ } .bt span:after{ content: "»"; /* */ opacity: 0; /* */ transition: 0.5s; /* */ } .bt:hover span:after{ opacity: 1; /* */ } $84.90
This is a sensor that detects oxygen concentration and supports three output modes: analog, I2C, and UART.
The probe has been calibrated at the factory, which can quickly and accurately measure the concentration of oxygen in the environment. Can be widely applied to fields like portable devices, air quality monitoring devices, industries, mines, warehouses, and other spaces where the air is not easy to circulate.
micro: Maqueen Lite with Skin (Blue) - micro:bit Educational Programming Robot Platform
9
micro: Maqueen Lite with Blue Skin (Installed)
Document .bt{ border: none; /* */ background: #0000FF; /* */ color: white; /* */ */ font-size: 28px; /* */ padding: 20px; /* */ width: 150px; /* */ border-radius: 20px; /* */ } .bt span{ transition: 0.5s; /* */ } .bt:hover span{ padding-right: 25px; /* */ } .bt span:after{ content: "»"; /* */ opacity: 0; /* */ transition: 0.5s; /* */ } .bt:hover span:after{ opacity: 1; /* */ } $36.90
Maqueen Lite is a STEAM educational programming robot. Despite a mini-body, it comes with an exquisite appearance and inherits the playability and simple operation of micro:bit.
The pretty skin not only makes it more popular with children but also effectively protects the core circuit from damage.
Other Models:     Green     White      Red
Beetle RP2040 Mini Development Board
10
 RP2040 chip, Smaller than Raspberry Pi Pico
Document .bt{ border: none; /* */ background: #0000FF; /* */ color: white; /* */ */ font-size: 28px; /* */ padding: 20px; /* */ width: 150px; /* */ border-radius: 20px; /* */ } .bt span{ transition: 0.5s; /* */ } .bt:hover span{ padding-right: 25px; /* */ } .bt span:after{ content: "»"; /* */ opacity: 0; /* */ transition: 0.5s; /* */ } .bt:hover span:after{ opacity: 1; /* */ } $6.90
Designed by Raspberry Pi, RP2040 features a dual-core ARM Cortex-M0+ processor with up to 133MHz clock and 264KB internal RAM, and supports USB 1.1 devices, which allows users to focus on function implementation instead of spending too much time and effort on improving codes.
DFRobot Beetle RP2040 is a development board built around the RP2040 chip. It has a compact size of 27mm×20mm, which is easy to be embedded into small devices or projects.
