【Back Feb 24th!】Holiday from Feb 14-23. All orders placed now will ship starting Feb 24th.
Recently, I saw many people creating smart-home equipment on the Internet, which aroused my interest, and then I created an automatic watering artifact which could surf the Internet. Programming of my device is based on DFRobot automatic watering kit. With ESP8266 module, the flower-watering kit could realize real time monitoring.
Required hardware:
As for mobile phone software, I used Blynk which is easy to build up and providing Arduino library. Throughout the communication, ESP8266 WiFi Bee module was used as communication module. Arduino is the main controller here.
1. Create A Blynk Item
Open Blynk software.
Add the following controls:
Adjust the size and arrangement of controls, and then set their parameters respectively, as follows:
| Control Name | Nature | Channel | Name |
| Value Display | Displaying humidity | V2 | HUMIDITY |
| Value Display | Displaying temperature | V0 | TEMPERATYRE |
| LED | Displaying watering condition | V4 | WATERING |
| LED | High temperature warning | V5 | HIGHTEMPERATURE |
| Slider | Setting watering threshold | V3 | SETWATERINGTHRESHOLD |
| Gauge | Displaying soil moisture | V1 | SOILMOSTURE |
Interface after adjustment is as follows:
Channels (pins) used in controls are virtual, which transmit data to ESP8266, and then ESP8266 transfers data to watering kit motherboard.
2. Download program to ESP8266
Switch ESP8266 WiFi Bee module to UART port, and plug it into xbee USB Adapter board, then connect to the computer. Select board FireBeetle-ESP8266 on Arduino IDE.(here is the link of
how to install the ESP8266 development environment.)
Download program to WiFi Bee ESP module, as follows:
After downloading, switch WiFi Bee ESP module to BOOT port.Note:before downloading program, you need to change your WiFi and password as well as the corresponding AUTHTOKENS code.
Program source code can be found here.
Open Arduino programmer, select Leonrdo motherboard and download source program to motherboard:
4. Hardware Connecting
Plug WiFi Bee ESP module into watering kit motherboard in right direction:
Assemble the watering kit:
Check the effect of watering…
