BLOG
ESP32
ESP32 blog features a wide range of content, including ESP32 projects, ESP32 tutorials, ESP32 news, and ESP32 selection guides, all related to this powerful microcontroller. Whether you're a seasoned developer or just getting started, this page has someth
  • How to connect the FireBeetle 2 ESP32-C5 to Home Assistant using MQTT - DFRobot
    Step-by-step Tutorial: Connecting FireBeetle 2 ESP32-C5 Development Board to Home Assistant Using MQTT
    Follow this step-by-step tutorial to connect the FireBeetle 2 ESP32-C5 to Home Assistant using MQTT. Learn to configure the Mosquitto broker, flash your board with Arduino, and display sensor data for your smart home automation projects.
    TUTORIALS ESP32IoT
    Aug 18 2025
  • FireBeetle 2 ESP32-C5 Review: Dual-Band Wi-Fi 6 & Solar Charging for IoT - DFRobot
    FireBeetle 2 ESP32-C5 IoT Development Board Review: Dual-Band Wi-Fi 6 and Solar Charging
    Explore the new FireBeetle 2 ESP32-C5, a powerful IoT development board featuring dual-band 2.4/5GHz Wi-Fi 6, multi-protocol support (BLE, Zigbee, Thread), and integrated solar charging. See how it outperforms the ESP32-C6 for advanced, low-power projects.
    REVIEWS ESP32
    Jul 15 2025
  • FireBeetle V1 vs V2 (ESP32/ESP8266/Arduino) Development Board Selection Guide - DFRobot
    The Selection guide comparing the FireBeetle (V1) and the FireBeetle 2 (V2) boards, particularly ESP32/ ESP8266 / Arduino versions.
    SELECTION GUIDE ESP32ESP8266
    Jun 08 2025
  • TinyML-ESP32 Integration: Cutting-Edge and Smart Home Automation Applications Overview
    6 Popular ESP32 AI Applications Using TinyML in 2024
    Explore the fusion of TinyML and ESP32 microcontrollers driving the AIoT revolution. Discover in-depth case studies, technical insights, and practical applications in environmental monitoring, health tech, and smart home automation.
    NEWS AIESP32
    Jun 18 2024
  • Guide to RISC-V MCU: Comparative Analysis of ESP32-C3, SiFive FE310, GD32VF103, and  K210 Development Boards
    Discover the powerful potential of RISC-V technology through leading products like ESP32-C3, SiFive FE310, GD32VF103, and Kendryte K210. Gain insights into how they meet the growing demands of IoT applications.
    Dec 20 2023
  • ESP32: WiFi Manager
    ESP32: WiFi Manager
    In this tutorial we will learn how to setup a WiFi Manager portal on our ESP32, using the Arduino core and the WiFiManager library. The tests shown below were performed on a ESP32-E FireBeetle board from DFRobot.
    TUTORIALS ESP32DFRobotEnglish
    Sep 28 2021
  • DFRobot ESP32 and Arduino Tutorial List: Everything You Need to Know
    250+ Must-read Tutorials for Learning ESP32 and Arduino
    Start your journey into the world of ESP32 development with DFRobot's comprehensive tutorials covering all the essentials.
    TUTORIALS ArduinoESP32
    Apr 29 2021
  • ESP32 Espruino Tutorial Menu
    ESP32 Espruino Tutorials Menu
    We’ve listed all the DFRobot ESP32 Espruino tutorials in this article.
    Apr 24 2021
  • ESP32 PS3 and PS4 Tutorial Menu
    ESP32 PS3 and PS4 Tutorials Menu
    We’ve listed all the DFRobot ESP32 PS3 & PS4 tutorials in this article.
    Apr 24 2021
  • ESP32 Soft AP Tutorials Menu
    We’ve listed all the DFRobot ESP32 Soft AP tutorials in this article.
    Apr 24 2021
  • ESP32 cpplinq Tutorial Menu
    ESP32 cpplinq Tutorials Menu
    We’ve listed all the DFRobot ESP32 cpplinq tutorials in this article.
    Apr 24 2021
  • ESP32 Arduino Tutorial Menu
    ESP32 Arduino Tutorials Menu
    We’ve listed all the DFRobot ESP32 Arduino tutorials in this article.
    TUTORIALS ESP32ArduinoDFRobotEnglish
    Apr 20 2021
  • ESP32 MicroPython Tutorial Menu
    ESP32 MicroPython Tutorials Menu
    Here are some micropython tutorials that we listed for you to experience its advanced features.
    TUTORIALS ESP32MicroPythonDFRobotEnglish
    Apr 01 2021
  • ESP32: Query mDNS service
    In this tutorial we will check how use a ESP32 to query a service advertised with mDNS.
    Jun 17 2020
  • ESP32 Arduino: Set static IP address
    In this tutorial we are going to learn how to setup a static IP address for our ESP32, using the Arduino core.
    Jun 17 2020
  • ESP32: Advertise service with mDNS
    In this tutorial we are going to learn how to advertise a network service available on the ESP32 using mDNS, and get information about that service on a Python program. The tests from this tutorial were done using a DFRobot’s ESP32 module integrated in a ESP32 development board.
    Jun 16 2020
  • ESP32: mDNS address resolution
    In this tutorial we will learn how to use mDNS to resolve the address of a HTTP web server hosted by the ESP32. The tests from this tutorial were done using a DFRobot’s ESP32 module integrated in a ESP32 development board.
    Jun 16 2020
  • ESP32: Getting pressure measurements from a BMP388 sensor
    In this tutorial we will learn how to obtain barometric pressure measurements from a BMP388 sensor, using the ESP32 and the Arduino core.
    May 25 2020
  • ESP32: checking if PS4 controller is charging
    In this tutorial we will learn how to check if the PS4 controller is charging or not, using the ESP32.
    May 25 2020
  • ESP32 PS4 Controller: Set LED flashing
    In this tutorial we are going to learn how to set the PS4 controller back led to flash with a given on and off rate, using the ESP32 and this library.
    May 25 2020
  • ESP32 SSD1306: Drawing a progress bar
    In this tutorial we are going to learn how to draw a progress bar on a SSD1306 OLED display, using the ESP32 and the Arduino core.
    May 25 2020
  • ESP32 PS3 Controller: Controlling a DC motor
    In this tutorial we will learn how to control a DC motor using the ESP32 and a PS3 controller.
    May 24 2020
  • ESP32 PS4 controller: controlling a relay
    In this tutorial we will check how to connect a PS4 controller to the ESP32 and control a relay by using the controller buttons.
    May 21 2020
  • ESP32 PS4 Controller: Setting the LED RGB value
    In this tutorial we will learn how to use the ESP32 to set the color of the RGB LED that is located in the back of a PS4 controller. We will be using the Arduino core and this library.
    May 21 2020
    • 1
    • 2
    • 3
    • 4
    • 15
    Page 1 of 15
