Bonjour,Comment réaliser le blink avec les datas en output ? Merci
JaneYu 2017-12-09 20:14:43 13 Views30 Replies Bonjour,
Hello, is this everything you need to make the ecg machine and connect it your phone? Thanks!
JaneYu This product does not link to a cell phone. If you need to connect to a cell phone you can use a controller with Bluetooth similar to Bluno.
Then use some Jumper wire to connect the sensor to the controller.
I wanted to know whether I could use the SEN0213 with an Arduino nano sense? I had troubles getting reliable readings with the nano sense, but the same code worked with the Arduino uno.
JaneYu Hi, The sensor is suitable for any motherboard that supports analog acquisition.
Hi Dan,
Sorry, it's not possible. The sensor is designed or optimized for detecting and measuring electrical impulses from brain.
JaneYu Will this product work with hand grip electrodes?
JaneYu Hi, witch hand grip electrodes do you want to use?
Hi, may I know the height of the ECG heart rate sensor? Only the length and width dimensions are given. Thank you
JaneYu I have zero experience or materials for soldering. Does this setup require soldering any pieces together?
JaneYu How can I convert the bit value generated on the serial monitor to actual voltage values? It is plugged into a 3.3 volt source.
JaneYu Hi
Is the pad color based on the rule of medical usecase?
I'm wondering why green pad is placed in right lower ribs in connecton diagrams. It is generally placed on left leg or left lower ribs.
JaneYu There is this link that I hope could help you:
https://wiki.dfrobot.com/He...
JaneYu How can I compute P, Q, R, S, T value from the sensor value?
JaneYu Through the heart rate conductor, it could get the relation of electic value, in the end, print the value follow the time order.
Hello
My question is why we used 3 lead ? why not 12 lead ? What is the basic justification
JaneYu Hi,
This product is not a medical device.So we needn't so many lead,3 lead are enough.
I would like to make a device that would detect an occurrence of a heart attack of the user and notify the family members using gsm.
JaneYu Oh, I don't think the accuracy of the sensor is up to that standard. We do not recommend that this sensor be used for medical purposes, we haven't done any tests on that, If anything goes wrong, it can be extremely dangerous.
Hi , is this sensor compatible with arduino due ?
JaneYu It should work, but 5V Arduino are recommended.
hello, how to realise the blink heart please ?
JaneYu You can find the first example code in the wiki, and when it reading analog signal, if the analog reading is bigger than a certain value, you can light the leds or let the leds blink, it's not a hard project, you can have a try first.
give me code
JaneYu URL for Arduino sketch is listed on last screen of video. It's at:
https://gist.github.com/vsq...
Thank you for your interest. Please let us know if you have problems.
