Recovering a potentially firmware bricked RS485 Soil NPK Sensor
derethan 2025-12-30 22:27:11 770 Views0 Replies Hello,
I have an RS485 Soil NPK Sensor that i purchased from DF robot over a year ago. The sensor has been built into an Arduino based device taking sensor readings consistently for the past years growing season.
Here is the sensor:
SEN0605
RS485 MODBUS-RTU Soil NPK Measure Sensor for Efficient Agricultural (IP68, 5-30V)
Wiki: https://wiki.dfrobot.com/RS485_Soil_Sensor_N_P_K_SKU_SEN0605
This past week i decided to work on some upgrades so that i could add an additional RS485 sensor to the system. In order to accomplish this i had to change the Device address so i could read from multiple RS485 Devices on the same Max 485 Chip.
For some context:
- I did NOT change any wiring or any of the code used to read the sensors or check for a device on a specific modbus address.
- The device was working as expected when i started that morning.
Here is what i did:
I ran the following to verify the device at the address, in this case address 1:
uint16_t NPKSensor::readCurrentAddress()
uint8_t result;
uint16_t currentAddress = 0;
// start sensor
startSensor();
delay(3000); // Wait for sensor to stabilize
// Log
Serial.println("Reading Current Modbus Address...");
// Read register at specified address
result = npkModBusNode.readHoldingRegisters(0x07D0, 1);
if (result == npkModBusNode.ku8MBSuccess)
currentAddress = npkModBusNode.getResponseBuffer(0x0);
Serial.print("Current Address: ");
Serial.println(currentAddress);
else
Serial.println("Failed to read current address! Check wiring.");
printModbusError(result);
// stop sensor
stopSensor();
return currentAddress;
This worked as expected and returned the device address of 1.
Then i used this function to try and change the device address (i supplies 2 as the parameter for the new address):
bool NPKSensor::changeSensorAddress(uint16_t newAddress)
uint8_t result;
// start sensor
startSensor();
delay(1000); // Wait for sensor to stabilize
Serial.println("Changing Modbus Address to 2...");
result = npkModBusNode.writeSingleRegister(0x07D0, newAddress); // Write new address (2)
Serial.print("Sensor address changed to: ");
Serial.println(newAddress);
// stop sensor
stopSensor();
return true;
else
Serial.println("Failed to change sensor address! Check wiring.");
// stop sensor
stopSensor();
return false;
After this, the Serial printed out that it had changed the address to 2.
Now it would appear i cannot read from the device at all. I have changed the device/slave address when setting up the modbus to to use the new address. I even tested a looping function to check and try and read the current address from all modbus ID's and got no response/timeout.
The only thing i can think of is that the stopSensor(); call (which turns off the mosfet powering the NPK sensor) not having a long enough delay after changing the address immediately cut the power to the NKP sensor before it had a chance to properly assign the new address to its EEPROM and now the sensor has a corrupt address.
Is there any knows recover methods for this sensor or a way to set it back to its factory defaults?
