Using MCC 172 DAQ on LattePanda: Is It Possible???
userHead hyeokjin.choi 2026-03-05 10:26:40 472 Views1 Replies
Hello!
I have a question regarding connecting a Dytran IEPE accelerometer to a LattePanda device.
On a Raspberry Pi, the MCC 172 DAQ HAT can be used to interface directly with IEPE-type accelerometers and acquire vibration data.
The MCC 172 works well for my application, but the Raspberry Pi is too slow for my processing requirements.
Since the MCC 172 appears to be designed specifically for the Raspberry Pi 40‑pin header, I am wondering if there is any possible way to use the MCC 172 with a LattePanda instead.
My questions are:
1. Is it technically possible to use the MCC 172 DAQ with a LattePanda board?
  (Even if I manually connect the required pins using a custom cable or breakout wiring.)
2. Does the MCC 172 require features that are only available on the Raspberry Pi
  (such as specific GPIO pin functions, kernel modules, or drivers)?
3. If hardware-level pin mapping is possible, is there any method to install or port the
  MCC 172 drivers so that it works on the LattePanda’s Windows environment?
Ultimately, my goal is to run the Dytran IEPE accelerometer through the MCC 172, but use a LattePanda instead of a Raspberry Pi because I need higher processing performance.
Any guidance or clarification would be greatly appreciated.
Thank you!!!
