Troubleshooting
seeMote Cube not connecting to VP via Bluetooth
userHead Tom.Westerlin 2026-10-05 07:10:39 674 Views5 Replies
Hi All!
I have a VisionPro running visionOS 27.2 - Mac on 27.0.1 - Xcode 27.2 - and can not connect the seeMote Cube to the VP.
The cube advertises and appears under Other Devices on a VP, pairing fails with Pairing Unsuccessful, and I have already flashed the latest firmware package and power cycled everything.
I think it the Cube is tied to my Mac laptop some how(even though I've forgotten it - even tried pairing with all other bluetooth devices off) How do I clear stored bonds on the cube?
Anything else I should try?
Thanks for the help!
T.
2026-11-03 09:26:27
Sorry for the confusion — "repair" was a typo for "re-pair" (delete the pairing and pair again). My bad.
Tom.Westerlin — reflashing the firmware is the only way the docs mention to reset the Cube's stored bond, so you've already covered that. Two last things worth trying before you give up on this unit: pair right after powering the Cube into pairing mode (hold the power button until the indicator flashes, not just an old broadcast), and turn your Mac's Bluetooth fully OFF during pairing — since the Mac was paired first, a leftover bond or the Mac grabbing it mid-pairing is the usual culprit for that "Pairing Unsuccessful" loop. The full checklist is in the connection guide, including the low-battery note:
https://wiki.dfrobot.com/dfr1280/docs/24782
If it still fails after that, I'd stop troubleshooting and contact DFRobot technical support directly with your order number — let them assess the unit and arrange a replacement if it checks out faulty. At that stage a hardware fault is the more likely explanation, and that's a call only they can make.
DJ.Segler — same story likely applies to your Cap: "great the first day, then won't hold a connection" is the classic stale-bond pattern. Forget the Cap in the host's Bluetooth settings, power-cycle it into pairing mode, and pair again. Also note the Cap runs a small 85 mAh battery (per its product page), so a low charge alone can look like an unstable connection — range and large metal objects are the other usual suspects in the same checklist above.
On multiple devices at once : that part is fine by design — the official wiki positions Cube and Cap as things you can deploy alongside each other, so one Vision Pro with several accessories is the intended setup:
What doesn't work is sharing one accessory across several hosts at the same time — it pairs with one host at a time, and you'll need to re-pair whenever you switch hosts.
userHeadPic Jason.Miao
Tom.Westerlin wrote:
Thanks for all the info Jason.Miao!
DFRobot tech-support said basically the same thing and yet it's still not connecting. They said I should ship the Cube back to them so they can inspect and repair.
Not sure how long this is going to take, but I feel I made a $300+ mistake!
2026-11-03 11:49:08
2026-11-03 06:03:26
I have a seemote cap with the same trouble. It worked great the first day, but as soon as I tried to use it again, I can't maintain bluetooth connection. I also need to use multiple devices at once and this seems to be a problem as well. Any advice?
userHeadPic DJ.Segler
2026-10-11 01:34:27
Thanks for the reply!
1) I did “forget” the Cube and removed it from the Mac (restarted) - this image attached now shows what the Mac sees.
2) on the Vision Pro I can not delete the Cube because it was never connected - image shows what it sees
3) I've updated the boot loader and restarted the Cube and tried it all again - same results UGGG
What do you mean about the forget+repair? What is repair?
Thanks for the help - at this point I'm frustrated and think it's the Cube and need a replacement. I should have not first connected it to my Mac before the AVP. My bad….
userHeadPic Tom.Westerlin
2026-10-08 09:10:39
Hello, here are my suggestions. You can give them a try. If they can solve your problem, that would be great.
Reflashing is effectively the cube's bond reset, and the official firmware page says to forget the device in the VP's Bluetooth settings after flashing, then pair again - so you're on the right track. That "Pairing Unsuccessful" usually comes from a stale bond key left on one side.
Try it in this order: 1) On your Mac, don't just "Forget" - remove it in System Settings > Bluetooth entirely (that deletes the Mac-side stored key). 2) On the Vision Pro, delete the cube under Other Devices too. 3) Power-cycle the cube (pull power, let it restart advertising) and pair with nothing else Bluetooth-enabled nearby.
If it still fails after that, the leftover bond-key is on the VP side - so power-cycle both and forget+repair on each device once more.
