LattePanda IOTA SBC
Cooling Solutions
WiFi Module
Expansion Board
Power Adapter
Protective Case
Touch Display
Quantity
LattePanda IOTA is a palm-sized x86 single-board computer, engineered for performance and versatility. As the next generation of the classic LattePanda V1, it packs an 8x faster Intel N150 processor, an RP2040 co-processor for real-time control, and a rich set of I/O ports. Designed for industrial automation, IoT gateways, smart retail, and light AI inference, the IOTA serves as a perfect partner for innovation.
For those migrating from LattePanda V1 or starting new projects, the LattePanda IOTA (8GB/64GB) Single Board Computer is the ideal entry point, priced at $129.00.
Seamless Upgrade: Retains the classic LattePanda V1 form factor for easy project migration
Maintaining the compact design (88mm x 70mm) and interface layout of the LattePanda V1, LattePanda IOTA enables effortless upgrades nearly without mechanical redesign or enclosure modifications, significantly reducing development time and preserving project continuity.
8x Faster Performance
With the Intel Twin Lake N150 quad-core processor (up to 3.6GHz) and LPDDR5 high-speed memory, LattePanda IOTA offers 8x the CPU performance of LattePanda V1, ensuring ample performance and multitasking capability for most applications.
Palm-Sized Design
Measuring only 88mm x 70mm, this compact LattePanda IOTA can be easily embedded into space-constrained applications like robots, smart terminals, and portable inspection devices—greatly expanding deployment possibilities for embedded systems at the edge.
Flexibility in Performance and Energy
LattePanda IOTA supports a configurable TDP (thermal design power) ranging from 6W to 15W, allowing for a balance between power consumption and performance according to the application scenario.
Rich I/O Connectivity
LattePanda IOTA provides a practical and comprehensive set of interfaces, including 3x USB 3.2 Gen2 (10 Gbps) ports, a Gigabit Ethernet port, HDMI 2.1 and eDP dual video outputs, plus M.2 E-Key and PCIe FPC expansion interfaces, which easily meets various peripheral connections through a single board.
Intel N150 + RP2040, Dual-Processor Collaboration
Alongside the Intel N150 processor, LattePanda IOTA also integrates an RP2040 co-processor, which features a dual-core Arm Cortex-M0+, offers abundant GPIOs, and can be dedicated to real-time I/O control, sensor data acquisition, motor drive tasks, or even emulate a custom HID device. This design effectively reduces the load on the main processor and enhances system responsiveness and functional versatility.
Moreover, compatibility with Arduino and MicroPython further reduces the barriers to hardware development and debugging.
How to Build a Perfect IOTA Kit
Creating a custom kit is straightforward. The following three simple steps outline everything needed.
1. Select an IOTA Board. Choose the RAM, storage, and Windows license option that best fits the project's demands.
2. Add Required Accessories. Every IOTA requires a cooling solution and a WiFi module to get started. These are mandatory selections.
3. Select Optional Expansions. Customize the build with a power supply, protective cases, displays, and powerful expansion boards to unlock the IOTA's full potential.
Please Note:
A LattePanda IOTA development board, a WiFi Module and a cooling solution are required for every kit.
The LattePanda IOTA board must have a heatsink installed before powering on!
Configure a Kit
Step 1: Choose a LattePanda IOTA Mainboard (Required)
The heart of the project. The LattePanda IOTA offers an 8x performance boost over the classic V1, an onboard RP2040 co-processor for real-time tasks, and a configurable TDP (6W-15W) to balance power and performance. All in the same palm-sized form factor for seamless upgrades.
Step 2: Select a Cooling Solution (Required)
Proper cooling is essential to unlock the IOTA's full potential and ensure system stability.
Step 3: Add Wireless Connectivity (Required)
Enable the project to go online with high-speed Wi-Fi and Bluetooth.
Step 4: Power the IOTA (Optional)
A stable power source is crucial for the system.
Step 5: Expand Functionality (Optional)
Enhance the IOTA's capabilities with dedicated expansion boards.
Step 6: Add a Protective Case (Optional)
Protect the investment with a rugged and functional case.
Step 7: Choose a Display (Optional)
Add a direct visual interface to the project with eDP touch displays.
Recommended Bundles
For a quicker setup, choose one of the expertly curated kits to get started instantly. Click a bundle to automatically select the components below.
Starter Kit
The perfect entry point. This kit includes everything needed to power on, get connected, and start creating with the LattePanda IOTA.
Configuration
IoT Developer Kit
Built for robust IoT deployments. This kit features the Windows-licensed IOTA, silent cooling, and versatile connectivity options like Power-over-Ethernet.
Configuration:
Portable Powerhouse Kit
Unleash the full potential of the IOTA on the go. This bundle combines top-tier performance with a large touch display and a UPS for uninterrupted mobile operation.
Configuration:
LattePanda IOTA Specification:
