Gravity: 7/24 Industrial Analog pH Meter Kit for Arduino
$56.90
SKU: SEN0169
  • $56.00 3+ items
  • $55.00 5+ items
  • $53.00 10+ items
Professional Arduino pH Sensor Kit with industrial electrode for long-term monitoring. Features easy connection, LED indicator, and linear output. Suitable for water quality and aquaculture applications.
Purchase this product and earn 569 reward points, which are tied to VIP membership program. Learn More >
Gravity: Analog pH Sensor / Meter Pro Kit For Arduino is a professional Arduino pH Sensor Meter Kit with an industrial electrode. The industrial ph sensor for Arduino has a built-in simple, convenient, practical connection and long life (up to 1 year), which makes it very suitable for long-term online monitoring. It has an LED that works as the Power Indicator, a BNC connector, and a PH2.0 sensor interface. To use it, just connect the pH sensor with the BND connector, then plug the PH2.0 interface into the analog input port of any Arduino controller. If programmed, you will get the pH value easily. You may also check Liquid Sensor Selection Guide to get better familiar with our liquid sensor series.
This industrial pH electrode is made of a sensitive glass membrane with low impedance. It can be used in a variety of PH measurements with fast response and excellent thermal stability. It has good reproducibility, is difficult to hydrolysis, and can eliminate basic alkali error. In 0pH to 14pH range, the output voltage is linear. The reference system which consists of the Ag/AgCl gel electrolyte salt bridge has a stable half-cell potential and excellent anti-pollution performance. The ring PTFE membrane is not easy to be clogged, so the electrode is suitable for long-term online detection.
You can find its spare probe here: Industrial pH Probe.
Attention:
The bottle cap of the probe contains protective liquid (3.3mol/L KCL). Even if the bottle cap is screwed tightly, some protective liquid may still leak around the bottle cap, forming white crystals. But as long as there is still protective liquid in the bottle cap, it will not affect the life and accuracy of the probe. So please use it with confidence. It is recommended that the white crystals be poured back into the protective liquid in the bottle cap.
Note: After you received your package! You may find some white particles on the protection foam which is the KCl crystallization from the cap. Please don't worry about the crystallization in the packing box, that's normal. Actually, since the transportation restriction on liquid, we have poured out the KCL3N solution in the cap, the slight crystallization in the packing box should be leaked since the remnant. Anyway, once you received the probe, you should store it in the KCL3N solution, you can not leave it in dry circumstances.
Good News: Gravity: Analog pH Sensor / Meter Pro Kit V2 is available now. As an upgraded version, the secondary generation pH meter pro greatly improves the precision and user experience.
  • Water Quality Surveillance
  • Aquaculture
  • Module Power: 5.00V
  • Module Size : 43mmx32mm(1.70"x1.26")
  • Measuring Range:0-14PH
  • Measuring Temperature:0-60 ℃
  • Accuracy : ± 0.1pH (25 ℃)
  • Response Time: ≤ 1min
  • Industry pH Electrode with BNC Connector
  • PH2.0 Interface (3-foot patch )
  • Gain Adjustment Potentiometer
  • Power Indicator LED
Dec 28, 2019
May 18, 2022
Selection Guide for DFRobot pH Sensors
Blog Selection Guide for DFRobot pH Sensors
Jan 13, 2025
DIY Hydroponics System using pH Sensor, EC Sensor, DS18B20, Ultrasonic, & ESP32
Tutorial DIY Hydroponics System using pH Sensor, EC Sensor, DS18B20, Ultrasonic, & ESP32
Electronic Clinic
Jun 06, 2024
IoT AI-assisted Deep Algae Bloom Detector w/ Blues Wireless
Projects IoT AI-assisted Deep Algae Bloom Detector w/ Blues Wireless
Kutluhan Aktar
Jan 12, 2023
GSM & SMS Enabled AI-driven (TinyML) Water Pollution Monitor
Projects GSM & SMS Enabled AI-driven (TinyML) Water Pollution Monitor
Kutluhan Aktar
Mar 31, 2022
Rafael.Zapata Oct 27, 2021
This product works very well, the sensor in like industrial sensor. the transmitter board (Electronic) it looks like DIY project. I recommended it for prototiping projects. the pH Sensore I will used 100% for a lot kind of projects.
Jens.Gilbers Feb 27, 2026
I use this Sensor in my DIY PH Doser project, and they serve their purpose :)
Muhammad Fadil.Huseiny Nov 05, 2025
Good working stable as intended
