Project 1: OBLOQ-IoT Module +Micro:bit IoT Flower Watering
Hardware list:
Gravity: UART OBLOQ – IOT Module (Microsoft Azure)
Micro:Mate - A Mini Expansion Board for micro:bit (Gravity Compatible)
Micro:bit - an Educational & Creative Tool for Kids
9g Metal Gear Micro Servo (1.8Kg)
One bottle and part of tube
Gravity: Analog Capacitive Soil Moisture Sensor- Corrosion Resistant
Project 2: Microbit Projects: Yes/No Bear
There are 2 possible answers. Either yes or no. We randomly generate the outcome when a button is pressed. When the answer is yes, the display will show Y & the tilt servo will response. When no, the display will show N and pan servo will response.
