This waterproof temperature sensor kit use DS18B20 probe AS. It contains a probe with a resistor module. So it is easy to connect on the Arduino board.
The DS18B20 temperature sensor provides 9 to 12-bit (configurable) temperature readings over a 1-Wire interface so that only one wire (and ground) needs to be connected from a central microprocessor. Compatible with 3.0-5.5V systems.
Check 27 Pcs Sensor Kit for Arduino to get more sensors for Arduino.
If you want to make a simple water purifier, we recommend buying together with Gravity: Analog TDS Sensor/Meter for Arduino.
Oct 21, 2025
Accurate and easy-to-use sensor
May 10, 2025
This is an amazing product
Jan 08, 2025
