This waterproof temperature sensor kit features a DS18B20 probe with a resistor module. It includes a pluggable terminal adapter, making it easy to connect to the Arduino board without soldering.
The DS18B20 temperature sensor provides 9 to 12-bit (configurable) temperature readings over a 1-Wire interface so that only one wire (and ground) needs to be connected from a central microprocessor. It is compatible with 3.0-5.5V systems.
For simple water purifier projects, it is recommended to use this kit together with Gravity: Analog TDS Sensor/Meter for Arduino.
Mar 17, 2026
I am using it for monitoring my Tank Temps in RDWC
Feb 27, 2026
I use this Sensor in my DIY PH Doser project, and they serve their purpose :)
Feb 08, 2026
Sensors are working great. Shipping was timely and tech support followed up quickly. Great communication. Thanks!
