Gravity: Waterproof DS18B20 Temperature Sensor Kit
$7.50
SKU: KIT0021
  • $7.20 3+ items
  • $6.90 5+ items
  • $6.50 10+ items
Waterproof temperature sensor with DS18B20 probe, easily connects to Arduino, offers 9-12 bit readings, supports 3.0-5.5V systems for multipoint measurement.
This waterproof temperature sensor kit features a DS18B20 probe with a resistor module. It includes a pluggable terminal adapter, making it easy to connect to the Arduino board without soldering.
The DS18B20 temperature sensor provides 9 to 12-bit (configurable) temperature readings over a 1-Wire interface so that only one wire (and ground) needs to be connected from a central microprocessor. It is compatible with 3.0-5.5V systems.
For simple water purifier projects, it is recommended to use this kit together with Gravity: Analog TDS Sensor/Meter for Arduino.
  • Operating voltage: 3.0~ 5.5V
  • ±0.5°C Accuracy from -10°C to +85°C
  • Usable temperature range: -55 to 125°C (-67°F to +257°F)
  • 9 to 12-bit selectable resolution
  • Uses 1-Wire interface- requires only one digital pin for communication
  • Unique 64 bit ID burned into chip
  • Multiple sensors can share one pin
  • Temperature-limit alarm system
  • Query time is less than 750ms
  • 3 wires interface:
    • Type A
      • Red wire - VCC
      • Black wire - GND
      • Yellow wire - DATA
    • Type B
      • Red wire - VCC
      • Yellow wire - GND
      • Green wire - DATA
  • Stainless steel tube 6mm diameter by 35mm(1.34") long
  • Cable diameter: 4mm(0.16")
  • Length: 90cm(35.43")
TDS Sensor & Arduino Interfacing for Water Quality Monitoring
Projects TDS Sensor & Arduino Interfacing for Water Quality Monitoring
Mamtaz Alam
Aug 22, 2022
Arduino Hydroponics, DIY Hydroponics System using pH Sensor & EC Sensor, Hydroponic
Projects Arduino Hydroponics, DIY Hydroponics System using pH Sensor & EC Sensor, Hydroponic
Electronic Clinic
Mar 22, 2021
How to make a Wobbly Penguin Arduino Robot
Blog How to make a Wobbly Penguin Arduino Robot
Jul 18, 2017
Jul 27, 2017
Danli
Nov 08, 2024
Kaj Ronny.Nilsen Dec 08, 2025
Great 1-wire sensor kit, easy to setup and use, having low latency at around 15ms. Random addresses means having many sensors at the same 1-wire bus is no problem. Recommended.
KOUBELAN RICHARD.AKPAGNI Nov 08, 2025
Excellent waterproof temperature sensor kit! The Gravity: DS18B20 is accurate, reliable, and easy to use with Arduino, ESP32, or Raspberry Pi. I tested it in an IoT project for liquid temperature monitoring, and it performed perfectly even in outdoor or humid environments. The stainless steel probe and sealed cable ensure full waterproof protection. Using the One-Wire interface makes wiring simple and allows multiple sensors on the same bus. The readings are stable and precise with fast response time. Ideal for weather stations, aquariums, or industrial applications. Great quality and documentation from DFRobot — highly recommended!
Chih.Kuo Oct 21, 2025
Accurate and easy-to-use sensor
