Gravity: Waterproof DS18B20 Temperature Sensor Kit
$7.50
SKU: KIT0021
  • $7.20 3+ items
  • $6.90 5+ items
  • $6.50 10+ items
Waterproof temperature sensor with DS18B20 probe, easily connects to Arduino, offers 9-12 bit readings, supports 3.0-5.5V systems for multipoint measurement.
This waterproof temperature sensor kit features a DS18B20 probe with a resistor module. It includes a pluggable terminal adapter, making it easy to connect to the Arduino board without soldering.
The DS18B20 temperature sensor provides 9 to 12-bit (configurable) temperature readings over a 1-Wire interface so that only one wire (and ground) needs to be connected from a central microprocessor. It is compatible with 3.0-5.5V systems.
For simple water purifier projects, it is recommended to use this kit together with Gravity: Analog TDS Sensor/Meter for Arduino.
  • Operating voltage: 3.0~ 5.5V
  • ±0.5°C Accuracy from -10°C to +85°C
  • Usable temperature range: -55 to 125°C (-67°F to +257°F)
  • 9 to 12-bit selectable resolution
  • Uses 1-Wire interface- requires only one digital pin for communication
  • Unique 64 bit ID burned into chip
  • Multiple sensors can share one pin
  • Temperature-limit alarm system
  • Query time is less than 750ms
  • 3 wires interface:
    • Type A
      • Red wire - VCC
      • Black wire - GND
      • Yellow wire - DATA
    • Type B
      • Red wire - VCC
      • Yellow wire - GND
      • Green wire - DATA
  • Stainless steel tube 6mm diameter by 35mm(1.34") long
  • Cable diameter: 4mm(0.16")
  • Length: 90cm(35.43")
TDS Sensor & Arduino Interfacing for Water Quality Monitoring
Projects TDS Sensor & Arduino Interfacing for Water Quality Monitoring
Mamtaz Alam
Aug 22, 2022
Arduino Hydroponics, DIY Hydroponics System using pH Sensor & EC Sensor, Hydroponic
Projects Arduino Hydroponics, DIY Hydroponics System using pH Sensor & EC Sensor, Hydroponic
Electronic Clinic
Mar 22, 2021
How to make a Wobbly Penguin Arduino Robot
Blog How to make a Wobbly Penguin Arduino Robot
Jul 18, 2017
Jul 27, 2017
Danli
Nov 08, 2024
w4e5ry.grea Apr 26, 2026
nice waterproof temperature sensor
Jan.Gruntmann Mar 17, 2026
I am using it for monitoring my Tank Temps in RDWC
Jens.Gilbers Feb 27, 2026
I use this Sensor in my DIY PH Doser project, and they serve their purpose :)
