7" 1024 x 600 IPS Display for LattePanda V1
$45.00
SKU: FIT0477
  • $43.50 3+ items
  • $42.50 5+ items
  • $41.50 10+ items
7" full-color IPS display with 1024x600 resolution, compatible with LattePanda V1. Insulated border prevents short-circuits; supports HDMI output.
Purchase this product and earn 450 reward points, which are tied to VIP membership program. Learn More >
Add exciting new dimensions to your project with this large full-color display. All you need to do is power your LattePanda V1 single board computer (not compatible with LattePanda Alpha & Delta) and you have a visual user interface for your project - no extra power cables required! The border of the display is insulated with black tape so that even without and enclosure there is no possibility of a short-circuit. The picture below shows a LattePanda directly powering the 7" display.
Note: LattePanda uses a custom MIPI pinout that will not be compatible with alternative IPS displays! You can still use HDMI out. Use your display in conjunction with the capacitive touch panel (not included) to get a touch interface for your project!
  • 7" IPS display
  • 1024 x 600 high resolution
  • Dimensions: 164.0mm x 96.0mm x 2.6mm
  • Supports LattePanda V1 (not compatible with LattePanda Alpha & Delta)
  • 10cm FPC connector
  • 7" 1024 x 600 IPS Display x 1
How to Make a Face Recognition Application with LattePanda?
Blog How to Make a Face Recognition Application with LattePanda?
Apr 03, 2018
How to use LattePanda and Blynk to make a simple IoT Control Unit?
Blog How to use LattePanda and Blynk to make a simple IoT Control Unit?
Apr 03, 2018
DIY A Steampunk Computer
Blog DIY A Steampunk Computer
Oct 31, 2016
ROMBUS PINBALL - A LATTEPANDA MINI PINBALL MACHINE
Blog ROMBUS PINBALL - A LATTEPANDA MINI PINBALL MACHINE
May 18, 2018
LattePanda + proximity sensing device
Blog LattePanda + proximity sensing device
Feb 07, 2018
Hyduino - Automated Hydroponics with an Arduino
Blog Hyduino - Automated Hydroponics with an Arduino
Nov 11, 2016
Paul.Crowe Aug 22, 2025
My Shopping experience was GREAT, Site is very responsive, and easy to navigate.
