Gravity: Digital 10A Relay Module
$3.90
SKU: DFR0473
  • $3.70 5+ items
  • $3.50 10+ items
  • $3.20 50+ items
The Gravity Digital Relay Module is compatible with both 3.3V and 5V devices, handling up to 10A current and supporting a wide voltage range of 2.8-5.5V.
Introducing the Gravity Digital Relay Module – the latest addition to DFRobot’s Gravity series! This module is a little different to the other relays in our store - not only is it compatible with 5V Arduino boards, but also with Raspberry Pi, BBB (BeagleBoard Black), mbed, Intel Joule, Arduino 101 and other 3.3V devices.
It is specially designed for low-voltage devices and works well under 3.3V power supplies, just like the Raspberry Pi relay board. In addition, the module has a wide range of power inputs. In our tests, once it reaches 2.8~5.5V, it can also support 1.8V devices.
DFRobot’s Digital Relay Module uses a high quality 3V relay. It can handle up to 10A current and mechanical parts are guaranteed up to 100 million uses. An on-board indicator LED demonstrates the relay’s state. Terminals include normally open (NO) and normally closed (NC). The module uses a Gravity-3 pin interface, which requires no soldering for convenient plug and play usage.
Gravity: Digital 10A Relay Module Connected With Raspberry Pi
  • Supports Arduino, Raspberry Pi, LattePanda etc.
  • 2.8 ~ 5.5V – A wide-range of input voltages
  • The underside of board is isolated using an acrylic plate for safety
  • Includes an LED Indicator
  • Uses a gravity-3 Pin interface for easy, plug and play usage
  • Operating Voltage: 2.8V ~ 5.5V
  • Input Signal: High Level (≥2.8V); Low Level (≤0.5V)
  • Max Switching Current: 10A
  • Max Switching Voltage: 35VAC; 30VDC
  • Rating Load: 10A@35VAC; 10A@28VDC
  • Max Switching Power: 300W
  • Operate Time: ≤10ms
  • Release Time: ≤5ms
  • Dimensions: 38 x 33 x 20 mm /1.5 x 1.3 x 0.81”
  • Mechanical Life: 1 million uses
  • Electrical Life: 50 thousand uses
  • Weight: 20g
  • Gravity: Digital Relay Module (with Acrylic Base) x 1
  • Gravity Digital Sensor Cable x 1
    Gun Away
    Projects Gun Away
    RoniBandini
    Feb 18, 2025
    UNIHIKER K10 Meets Harry Potter: Build an AI Magic Wand
    Projects UNIHIKER K10 Meets Harry Potter: Build an AI Magic Wand
    Yeez_B
    Sep 25, 2025
    DIY Smart Bathroom Light: with ESPHome & Home Assistant!
    Tutorial DIY Smart Bathroom Light: with ESPHome & Home Assistant!
    Mellow_Labs
    Aug 19, 2024
    Kaj Ronny.Nilsen Dec 08, 2025
    Great relay module for 3.3V microcontrollers, easy to setup and use, recommended.
    K Nantha. Jun 20, 2020
    Great, received in good conditions.
