The TF02-Pro is a TOF single-point solid state LIDAR. The TF02-Pro is based on the TF02 and has been significantly upgraded and optimised to achieve a range of up to 40 m. The more efficient optical system and better circuit design ensure higher range performance. It can be widely used in the fields of UAV height fixing, intelligent transportation, intelligent parking, intelligent agriculture, etc.
High Performance
Longer and More Accurate Measurement
The TF02-Pro ToF LiDAR sensor can measure distances up to 40m, with a blind spot as low as 10cm, supports a refresh rate of up to 1000Hz and has an optimised and upgraded algorithm for more accurate ranging.
Small Size
This solid state lidar sensor is only 69mmx41.5mmx26mm, and its weight is only 50g.This mini size allows you to integrate it into small applications.
How does TF02-Pro LiDAR work?
TF02-Pro ToF Single-Point Ranging Solid State LiDARis a newly developed product based on the widespread application experience of TF01. It is a unidirectional laser rangefinder, which is based on ToF (Time of Flight) technology. It is comprised of particular optical and electrical devices that make it stable, high sensitivity, and high precision.
Note: the side length of detecting range is not equal to the object resolution at the corresponding distance.
Apr 02, 2023
Works well out to 40 meters and has survived several nights of below freezing temperatures.
