BOSON Science Kit
SKU: TOY0084
A digital science kit for young scientists, including 8 sensors for STEM exploration, a plug-and-play monitor, and activity cards. Suitable for IoT projects.
Contact Us
Boson science kit is a set of digitalized scientific exploration tools for a young scientist to build their hands-on STEM lab.
Boson science kit brings kids:
8 scientific sensors for physics, chemistry, and biology.
Activity cards that guide kids to start a scientific exploration on 8 different topics.
Plug and play LED monitor for instant result display.
Infinite possibilities of combining the sensors with micro: bit, Arduino, and other Boson modules.
BOSON Science Kit
BOSON Science Kit
Boson science kit includes 8 sensors that are most widely used in modern IoT applications, all built with industrial standards. Unlike traditional science kits, Boson scientific sensors output an instant and accurate result in the form of electric signals. Setting up the device is extremely easy, and all the sensors can be used repetitively.
The measurement can be read directly from the display module. Moreover, you can connect other Boson modules to create an automatic device, or use a micro: bit/Arduino to record the data and even upload it to a cloud server.
BOSON Science Kit
WARNING:
The pH sensor contains liquid. Adult supervision is strongly recommended for children under 12 years old.
More about BOSON
Tutorial List
EP01 What Color Absorbs Heat Best?
https://edu.dfrobot.com/makelog-308147.html
EP02 Which Coffee Cup is BEST?
https://edu.dfrobot.com/makelog-308173.html
EP03 What's the pH value for various liquids?
https://edu.dfrobot.com/makelog-308178.html
EP04 What happens when acid meets base?
https://edu.dfrobot.com/makelog-308161.html
EP05 Why is the water changing its color?
https://edu.dfrobot.com/makelog-308185.html
EP06 Do plants grow better with fertilizer?
https://edu.dfrobot.com/makelog-308229.html
EP07 Do plants need light?
https://edu.dfrobot.com/makelog-308235.html
EP08 Do plants grow better with more water?
https://edu.dfrobot.com/makelog-308254.html
EP09 What's the best environment for a plant?
EP10 Can pure water conduct electricity?
https://edu.dfrobot.com/makelog-308259.html
EP11 Are we able to ‘see’ conductivity?
https://edu.dfrobot.com/makelog-308263.html
EP12 What happens to your body during a workout?
https://edu.dfrobot.com/makelog-308264.html
  • Operating Voltage: 4.5V-5.5V
  • Dimension: 60 x 220 x 300 (mm)
  • Weight: 1800g
Sensor:
  • Light sensor x1
  • Humidity sensor x1
  • Soil moisture sensor x1
  • Temperature sensor x1
  • Waterproof temperature sensor x1
  • pH sensor x1
  • Conductivity sensor x1
  • Heart rate monitor x1
  • Display:
  • OLED display module
  • Power:
  • Mainboard 1IO x1
  • Mainboard 3IO x1
  • 3xAAA Battery Holder
  • Accessories:
  • Project cards x8
  • Cable (5CM) x10
  • Cable (10CM) x10
  • Cable (15CM) x10
  • Velcro pack x1
  • Screw pack x1
    DFRobot BOSON Demo Project 03- Make a Binary Half Adder
    Blog DFRobot BOSON Demo Project 03- Make a Binary Half Adder
    Jun 02, 2017
    DFRobot BOSON Demo Project 02 - Make a Walking Robot
    Blog DFRobot BOSON Demo Project 02 - Make a Walking Robot
    Jun 01, 2017
    DFRobot BOSON Demo Project 01- Make an Electronic Candle
    Blog DFRobot BOSON Demo Project 01- Make an Electronic Candle
    May 27, 2017
    DFRobot Science Lab S01
    Course DFRobot Science Lab S01
    Nov 27, 2024
    A Science Experiment: Conductivity of Salt Solution with micro:bit
    Projects A Science Experiment: Conductivity of Salt Solution with micro:bit
    qianqian.xua
    Feb 04, 2024
    Build and Test Earthquake Proof Buildings with BOSON and micro:bit
    Projects Build and Test Earthquake Proof Buildings with BOSON and micro:bit
    Danli
    Jun 26, 2023
